  1. Dismiss Notice
New bulbs for my solar duo boy 13watt
Discussion in 'Lighting' started by Asthaparhim, Aug 13, 2013.
  1. Asthaparhim
    Asthaparhim Junior Poster
    Sep 25, 2012
    2:50 AM
    Hello!
    I am using 2x solar duo boy 13watt, but I want to replace the bulbs.
    In an article I found on the internet, the aquascaper also uses solar duo boy 13w but he is using phillips 14watt bulbs.
    However, in my country I can only get these (only 2700k). Will it work if I want to grow a carpet of HC or isn't it enough?
    Maybe someone can advice me other bulbs if they are not good enough?
    Thank you in advance!
    #1 Asthaparhim, Aug 13, 2013
  2. Asmack Arabia
    Asmack Arabia Banned
    Nov 1, 2012
    145
    2:50 AM
    gsa
    i am using solar duo boy too, but the 26watts type. 2700k is too yellowish. i am using the regular Osram CFL at 6500k and my plants are doing fine. you can try to order online if the 6500k is not available in your country but i am sure it is...
  3. Asthaparhim
    Sep 25, 2012
    2:50 AM
    Thanks!
    I came across these phillips 14watts, they're the ones I need?
    Can't find osrams of 6500k only 5000k and lower.
  4. Asmack Arabia
    Nov 1, 2012
    145
    2:50 AM
    that's great to hear. yes, that color temp will do. as i said, i have the 26watts type fixture but i reduced the wattage of the CFLs I am using to 15watts. i was getting some hair algae before and i decided to reduce the light intensity.
  5. Asthaparhim
    Sep 25, 2012
    2:50 AM
    Thanks for your help!
