New ADA 60p non CO2, no excel etc, for L046 Zebra plecos
771
I'm sort of okay with it. It's infested with 100+ cherry shrimp. I'm not liking the mass of Water sprite look. I need to give it more time to decide whether I will make any changes. It's a very easy to care for aquarium.
I might switch to more mosses and Anubias, they look pretty good and the moss has very nice capillary action to bring water to other plants higher up on the wood.
HC also will look good on this.
I might phase the water sprite out slowly and decide that way. The wood has fully matured and does not move around during water changes. So perhaps this week I'll add fish.
dutchy
62
The Netherlands
Ok...can you post a nice picture with the fish? I (and I'm sure not just me) would like to see the result.
Beautiful fish those zebras.
771
And
Fish are in there but hide.
100? CRS are also in there.
Bolbitus is growing without any CO2/Excel etc.
771
I'm not as keen on the massive weedy growth of the Water sprite, some like it, but I'm after something a little bit more subtle, I hacked it way back, and I have to trim the roots about once a month.
Where I am going is more moss on branches and Anubias. I might train the pennywort on this as well. HC just started growing after being infested in some moss, so I will allow that to grow. Bolbitus looks decent emergent in another tank, but I like the Anubias better mixed with moss. Need to think more about other species to try that will give me a nice look and not end up with weedy roots everywhere.
771
Tank is pretty easy to care for, I use a sponge prefilter on a Rena 3 that gets cleaned about once every 3 months. I'll pick off dead leaves, but it's easy since they grow out of the water, easy to get too, moss acts as the water conduit for higher growing plants.
There is a lot more Anubias than you can see.
I'm letting the pennywort and Water sprite take over a bit more.
The roots and the shoot of the water sprite are both trimmed, not just the leaves/stem/shoot.
Ekrindul
Jul 9, 2010
114
Euless, TX
Tom,
Any chance you might give us a rundown of how you set this up, how you are dosing this tank, etc.? I would love to set up something like this as a 3rd low maintenance tank, but I'm not sure how some of this works. The anubias & mosses are obvious, but what about the water sprite and worts. It appears they are just attached to the wood and gather nutrients from the water collumn with the large root systems, which I assume is why you chose these plants? Are there other plants you could have used in their place? Say h difformis? Any possibility of emergent echinodorus working in this setup, or is that silly?
I really like this setup due to the optimal viewing of the fish vs a paludarium setup, while still allowing for emergent growth.
C
csmith
Alright, I've tried finding the answer. How does the emergent growth stay alive while also being out in the open like that? I don't see how the tank could be producing enough humidity to to keep all of that happy. Does it just acclimate to the extreme drop in humidity?
771
It's really dry here in CA.........the roots are fine if they are in the water, the moss acts as a conduit for the water via capillary forces.
Also, moss is sort of the "sediment" for some plants.
The tops of the wood and maybe 2-3" down, I wrapped and used cotton thread for the moss, and also wrapped the Anubias. Penny wort an d water sprite just are sitting on top of that and will root fuse into the moss after awhile.
It is very self explanatory if you look at the pics, just time and moss "creep" really.
C
csmith
I get and understand all of that. I moreso meant the stem growth out to the left of the tank and the high growth under the lights. Those sections specifically, do they not require the moisture? Basically what I'm getting at is once a plant is emergent, does it adapt to the surrounding environment as long as its root structure has the moisture it needs?
The only emergent growth I've dealt with is a DSM tank, so this is obviously a bit counterintuitive to what I thought I knew on the subject (i.e. the leaves still need to be kept in a humid environment).
771
I removed the Water sprite, but it'll be a few weeks till the other plants fill in, I might get a good sized Anubias for that corner I think.
I think this will look better.
nipat
May 23, 2009
665
Reading somewhere you dose the tank by spraying fert solutions?
If so, won't the leaves get fert residue on them? :confused:
771
dutchy;56213 said:
Pretty,
I might start something like this on the Killifish tank I'm planning.
regards,
dutchy
You you like dried fish or something?
Killifish are reknown for their ability to jump out even closed hoods:)
771
That is the idea. Ferts on the plants, not in the water.
Ran a CO2 meter on the tank, reads about 2-3ppm.
dutchy
62
The Netherlands
Bad idea...they are way too expensive for that. Thnx for the warning. :)
regards,
dutchy
771
I have kept clowns and Golden Australs for awhile, never had one last long in an open top tank.
EVERY one jumped.
