New 40B in planning....
Discussion in 'Are you new to aquatic plants? Start here' started by Doc7, Feb 20, 2017.
  1. Doc7
    Doc7 Member
    Apr 19, 2011
    136
    11:00 AM
    Hello all,
    Considering the following, what do you think?
    - 40 Breeder
    - 2 x 36" Finnex Stingrays, mounted on legs on tank rim
    - 2-3" sloped front-back Eco Complete Substrate (5 bags, for average 2.5" depth)
    - 1 x Eheim 2217 filter with inline Hydor heater and a Fluval surface skimmer
    - Dosing per Tom Barr Non CO2 Methods:
    "User said:
    While trace mixes can be added, I decided to use SeaChem Equilibrium instead.
    It has Fe and Mn as well as Ca/K/Mg/SO4.
    I will add about 1/4 teaspoon per 20 gal tank once every week or two.
    This greatly enhances the growth of the plants.
    I also will add about 1/8" and 1/32" teaspoon of KNO3 and KH2PO4 respectively once a week or two."
    I will test my (well) water with GH/KH, for some advice - i notice there is no additional iron in the Tom Barr dosing. Do you think this will all be satisfactory?
    - Thinking about doing an Ammonia cycle with just substrate and wood in tank before buying plants and fish. With a Low Tech Low Light tank will plants pull up enough ammonia for a "Silent Cycle" instead?
    would you recommend aquasoil Amazonia vs the
    ecocomplete?
    thank you!
  2. Pikez
    Pikez Rotala Killer!
    Staff Member Moderator
    May 12, 2013
    1,962
    1,465
    11:00 AM
    If you're going with Finnex, look into a blend of Planted+ and MonsterRay. I understand it is a personal preference, but these two look and work really well together.
    Seachem Equilibrium is not a trace or comprehensive fertilizer. Flourish + Equilibrium fits the bill better. GH chemicals are real cheap if you buy them separately. Some pre-mixed GH boosters turn into a rock after a few months. You're better off using powder dosing with KNO3 and KH2PO4.
    Aquasoil is certainly a better nutrient source than EcoComplete. But Aquasoil can be somewhat messy during cleaning times.
  3. Dale Hazey
    Dale Hazey Junior Poster
    Feb 18, 2017
    165
    144
    11:00 AM
    I am no expert on any of this...
    Tom has said that eco complete is inert(without-nutrients) Except iron?
    it's just clay substrate? Look into turface, people talk about using that along with other cheap clay alternatives, I imagine it's way cheaper than eco complete.
    I would use cheap substrate like pool filter sand, or a cheap clay substrate, and just dose the water column.
    Aren't those finnex stingrays kinda strong lights? I would think without excel or Co2 you would want a short photoperiod to reduce the chances of algae.
    I tried a silent cycle in my 40breeder, it seemed to work well until I pulled a bunch of stem plants and added more fish too fast. Then it crashed, the key to a silent cycle is probably a high plant biomass, while very slowly adding the fish and critters.
    #3 Dale Hazey, Jun 29, 2017
  4. Braineto
    Braineto New Member
    Jun 29, 2017
    6:00 AM
    2x Stingray's is very good option. Personally I like its color temp.
    If by any means you can hang a fixture over the tank, go with Fluval Plant 2.0, it need to be raised 3-4" inches to get the full coverage/spread over a 40 breeder. Fluval is a very quality light if compared with Finnex Stingray, with 3 years limited warranty and waterproof.
    If paying for substrate pay for Aquasoil or else go with cheaper alternatives (turface or pool filter sand). Eco-complete is crushed lava rock, its very easy setup a tank , just dump into the tank and fill water.
Similar Threads - 40B planning
  1. bshenanagins
    25
    1,628
  2. slipfinger
    6
    805
  3. Soidfuf
    13
    1,663
  4. slipfinger
    764
  5. sjb2487
    422
