Brand new (still in protective packaging)Hach DR-890 Portable data logging Colorimeter
Here’s your chance to own the top-of-the-line Hach (800 series) colorimeter available for approximately $350 off of the price new!.
Highlights
Preprogrammed: ready-to-use out of the box!
Automatic wavelength selection
Compact: true hand-held analysis, for use anywhere
Rugged: dustproof, waterproof, shockproof, worry-free (designed to meet IP67 standards)
Powerful: full datalogging and RS232 interface capabilities
Simple: menu-driven, step-by-step analysis
Batteries-/Accu operation possible, Real-Time-Clock, integrated Timer, Data Memory with 100 measuring values and automatic AutoOff-Function. Wavelengths: 420 nm, 520 nm, 560 nm and 610 nm.
• Dustproof, waterproof, shockproof, and worry free
• High-value, high-capability field instruments for water quality analysis
• More Advanced Features that Add Value
• Simplify Data Management
• Easy Quality Control
Included with this Brand new Hach DR890 colorimeter>Sample cells – (2) round, with 10-ml, 20-ml, and 25-ml marks
>COD/TNT adapter for use with 16-mm vials used in COD and Test ‘n Tube methods
>Batteries – (4) AA alkaline
>Documentation package –binder with Instrument Manual & Procedures Manual
> Handy laminated chart of stored programs (97 tests)
Summary
The Hach DR890 colorimeter is a microprocessor –controlled, LED-sourced filter photometer suitable for colorimetric testing in a laboratory or the field. The instrument is pre-calibrated for common colorimetric measurements and includes convenient calibration capability for user-entered and future Hach methods.
Don’t miss out on this fantastic opportunity!
Only $700
(Over $350 savings!)
Can ship
(Insurance highly recommended)
___________________________________________________________________________________________
Can ship
The following table lists the wavelengths used in the DR/890 Colorimeter instrument. The DR/890 Colorimeter uses four different wavelengths: 420, 520, 560, and 610 nm.
Parameter Program Number Wavelength (nm)
Aluminum (Aluminon) 1 520
Aluminum User 610
Benzotriazole 3 420
Boron, LR 4 420
Bromine 5 520
Bromine (AV) 6 520
Cadmium User 560
Chloramine, Mono, LR 110 610
Chlorine, Free 9 520
Chlorine, Free (AV) 11 520
Chlorine, Free (TNT) 10 520
Chlorine, Free, HR 8 520
Chlorine, Free, HR+ 12 520
Chlorine, Total 9 520
Chlorine, Total (AV) 11 520
Chlorine, Total (TNT) 10 520
Chlorine, Total, HR 8 520
Chlorine, Total, HR+ 12 520
Chlorine Dioxide (DPD) 112 520
Chlorine Dioxide (DPD, AV) 113 520
Chlorine Dioxide, MR (Direct read) 7 420
Chromium, Hexavalent 13 560
Chromium, Hexavalent (AV) 14 560
Chromium, Total 15 560
Chromium User 520
COD, LR 16 420
COD, HR 17 610
COD, HR+ 17 610
COD, Mn III 18 520
Color, True and Apparent 19 420
Copper (Bicinchoninate) 20 560
Copper (Bicinchoninate, AV) 20 560
Copper (Porphyrin) 22 420
Copper User 420
Cyanide 23 610
Cyanide (Europe Only) User 560
Cyanuric Acid 24 520
DEHA 25 560
Fluoride 27 610
Fluoride (AV) 28 610
Hardness, Ca 29 520
Hardness, Mg 30 520
Hydrazine 31 420
Hydrazine (AV) 32 420
Iron, Ferrous 33 520
Iron, Ferrous (AV) 33 520
Iron, Total (FerroVer) 33 520
Iron, Total (FerroVer, AV) 33 520
Iron, Total (FerroMo) 38 610
Iron, Total (FerroZine) 37 560
Iron, Total (TPTZ) 39 610
Iron, Total (TPTZ, AV) 39 610
Iron User 520
Lead User 520
Manganese, LR 43 560
Manganese, HR 41 520
Molybdenum, HR 44 420
Molybdenum, HR (AV) 44 420
Molybdenum, LR 47 610
Nickel (PAN) 48 560
Nickel User 520
Nitrate, LR 55 520
Nitrate, MR 54 420
Nitrate, MR (AV) 53 420
Nitrate, HR 51 520
Nitrate, HR (AV) 50 520
Nitrate, HR (TNT) 57 420
Nitrite, LR 60 520
Nitrite, LR (AV) 62 520
Nitrite, LR (TNT) 63 520
Nitrite, HR 59 560
Nitrite (Europe Only) User 520
Nitrogen, Ammonia, LR 64 610
Nitrogen, Ammonia, LR (TNT) 66 610
Nitrogen, Ammonia, LR User 610
Nitrogen, Ammonia, HR (TNT) 67 610
Nitrogen, Ammonia, HR User 610
Nitrogen, Total, LR (TNT) 58 420
Nitrogen, Total HR (TNT) 69 420
Nitrogen, Total Inorganic (TNT) 68 610
Nitrogen, Total Kjeldahl 65 420
Oxygen, Dissolved, LR 71 610
Oxygen, Dissolved, HR 70 520
Ozone, LR 72 610
Ozone, MR 73 610
Ozone, HR 74 610
pH 75 520
Phosphonates 80 610
Phosphorus, Acid Hydrolyzable (TNT) 82 610
Phosphorus, Reactive (PhosVer3) 79 610
Phosphorus, Reactive (PhosVer3, AV) 79 610
Phosphorus, Reactive, LR (TNT) 82 610
Phosphorus, Reactive (Amino Acid) 85 520
Phosphorus, Reactive, HR 77 420
Phosphorus, Reactive, HR (AV) 78 420
Phosphorus, Reactive, HR (TNT) 86 420
Phosphorus, Reactive, LR User 610
Phosphorus, Reactive, HR User 610
Phosphorus, Total LR (TNT) 82 610
Phosphorus, Total HR (TNT) 87 420
Phosphorus, Total, LR User 610
Phosphorus, Total, HR User 610
Silica, LR 90 610
Silica, HR 89 420
Silica, UHR 88 420
Sulfate 91 520
Sulfate (AV) 92 520
Sulfate User 420
Sulfide 93 610
Surfactants 26 610
Suspended Solids 94 610
Tannin and Lignin 98 610
TOC, LR 116 610
TOC, MR 117 610
TOC, HR 115 610
ToxTrak 61 610
Turbidity 95 520
Volatile Acids 96 520
Zinc 97 610
Zinc (Europe Only) User 520
