neo 90 reef conversion
Discussion in 'General Plant Topics' started by dougiefresh, Jan 1, 2011.
  1. dougiefresh
    dougiefresh Junior Poster
    Oct 24, 2006
    1:14 AM
    I'm converting a deep sea aquatics neo 90 3x2x2 ft to a planted tank with a PM Sump. I don't like the look of the large BLACK overflow right in the middle. Is there some more more discreet doing an overflow and drain with maybe clear pipes if I remove the overflow black box. Would of course want it to be reliable. Or should I just remove the overflow all together and sump and get a canister.
    I want to do a some large branchy pieces of driftwood and rocks, it will be open top, so would like some of the pieces stick above the water.
    Any ideas would be great...
    Thanks, DEF
  2. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    1:14 AM
    You can use the CPR brand of hang on overflow. They do not use a U shaped siphon tube and are very nice. I know Tom uses them on his 180.
    Let me know if you can remove the overflow box. I have 2 on my 180 that I am dying to remove.
    You can remove the wier and still have a sump. You would just lose the SKIMMING action the overflow wall provides.
