Needing Expert Advice On Lighting For Low To Medium Light Plants
#1 Plant Boy
Aug 22, 2018
13
39
Washington State
I have a 55 gallon breeder aquarium with a 48 inch fluval' 2.0 over it.The light fixture is controllable with a wifi' controller. The plants that I am using are low to medium light plants. I will be injecting c02. I want to get the best growth and color from the plants. What would you suggest on the light intensity percent since I can control the light from 0 to 100 percent? Also how long should I keep the lights on for?
محمدرضا
Aug 25, 2019
6
43
iran
محمدرضا
Aug 25, 2019
6
43
iran
hi
Depending on the type of light.if use led light You have to consider the lumen and if t5 or t8 lamps are your light,watt on litres is important.
