Need suggestion on carpet plant + C02 questions
Discussion in 'Are you new to aquatic plants? Start here' started by PunkRotten, Feb 19, 2011.
  1. PunkRotten
    PunkRotten Junior Poster
    Aug 1, 2010
    23
    8:46 PM
    Hello,
    So I got a 10 and 29 gallon planted tank. I wish to have a lawn in these tanks. Right now I have dwarf hairgrass in both tanks and I have been dosing excel. For months now it has not been growing well. It grows a little in the 10 gallon but not in the 29. So I was looking for an easier plant.
    Heres the stats on my tanks:
    10 gallon
    (2) Two GE 15 watt CFL bulbs (both 6500K), lights on a timer for 8 Hrs daily
    Eco complete substrate
    Daily excel dosing (2x recommended dose)
    Weekly fert dosing of potassium nitrate, mono potassium phosphate, and seachem equilibrium (which is a powder that contains iron, potassium, calcium, magnesium, manganese etc)
    Weekly water changes of 25-30%
    Plants: Dwarf hairgrass, rotala indica, dwarf sag, crypts, java fern, java moss on wood
    Fish: 5 neon tetras, 1 female betta, 3 ottos
    29 gallon
    Coralife dual T5NO bulbs (6500K, and colormax bulb), lights on a timer for 9 Hrs daily
    Eco complete substrate mixed with regular play sand
    Same fert dosing schedule as 10 gallon tank, but higher amounts
    Same water change schedule as 10 gallon
    Plants: Dwarf hairgrass, rotala indica, crypts, java fern, java moss on wood, dwarf lily, wisteria
    Livestock: Few CPO's, and 4 ottos
    What would be a good carpet plant and could I do without C02? If I should add C02, what do you recommend? DIY or a cheap kit like around $40 or under?
  2. Matt F.
    May 30, 2009
    2,319
    8:46 PM
    hairgrass is about as easy as it gets when it comes to foreground plants...at least in my experience.
    That said, equilibrium isn't a micro suppliment per say. Sure it has some elements, but it's my understanding that equilibrium is mostly potassium sulfate (gh booster). You need micros, too.
