Hello to all experienced members of this forum. A little background about my experience and situation. I am fairly new to aquatic tanks. I have a non-planted 90 gallon (48x24x18 inches) tank since 2 years. I am new to this site but I have been silent reader of plantedtank.net since last 2 years.
Planted tanks are very uncommon in my country, Pakistan. The only aquatic plants I can buy are Amazon swords and Anubias nana. Very occasionally we get some carpet plants from Thailand. Chemical of N, P, K are not available or sold separately due to risk of being used in explosives. My only option is to either use dirted tank OR use growmore water soluble fertilization (http://www.growmore.com/products/type/water-soluble-fertilizer.html). I am using 20 20 20 solution as thats the only product available here
These beautiful lush green planted tanks were becoming an obsession for me. So just to experiment what I can manage in this limited availability of things, I finally ordered some items from AliExpress. I am not too optimistic that things will turn out good but I need help like Tips and suggestions to make this into something.
I received following items about 2 months ago.
1 - Aquatic plant seeds (some sort of grass seeds and probably glosso).
2 - Chichiros 45cm light
3 - DIY CO2 setup
Lighting on below setup is a 13 watt Philips 6500K LED bulb. Chichiros will be used on 10 Gallon setup coming below.
Day 0:
I setup a small 2-3 gallon bowl to test these seeds about 1 month ago. Here are its results. I am still not sure if these plants are aquatic or not. Some unknown sand at the base, then a layer of organic potting soil (some brand imported from UK) then some more sand.
Dry Start Stage:
Misting water two times a day. Progress after 4 days.
Submerged at 7-8 days:
DIY CO2 was added on and off after submerged. Daily water changes around 30% with little bit of growmore fertilization every 2-3 days.
After 3 weeks of submerged growth:
Plant leaves have changed its shape. Probably changing from emersed to submerged growth.
QUESTIONS
- Plants seem to be growing but their colors are very light green. Is this due to light? color spectrum or fertilization?
- Water turns little green on the day I add growmore fertilization. I am doing daily water changes but fertilization is added on 3rd day. Is it due to the ratio I am using 20:20:20 NPK and micro as:
- I added a tiger lotus in this tank which has been with me since a year. When added, it started growing new leaves but leaves are a little twisted and small in size.
- I don't have any plans of fish in this aquarium. But I have just started the 10Gallon tank using similar setup which I plan on adding fish in a month or two. Will my fertilization be hazardous to fish health? I don't have access to test kits. They are not available on Aliexpress. Amazon doesn't ship to my country .
Hassan
3 - DIY CO2 setup
Day 0:
Dry Start Stage:
QUESTIONS
Hassan
