Need help to identify and control algae
Discussion in 'Algae Control' started by Ganesh, Jun 30, 2017.
  1. Ganesh
    Ganesh New Member
    Jun 27, 2017
    13
    4:00 PM
    IMG_20170629_215449556.jpg Hi guys,
    Please look at the pic and help me in identifying and controlling this algae.
    I will be grateful. :)
  2. DutchMuch
    DutchMuch Junior Poster
    Mar 8, 2017
    1,033
    385
    10:30 AM
    looks like regular, Algae, to me lol think its called green dust algae or something? Less light can help or even out your dosages of ferts
  3. Ganesh
    Ganesh New Member
    Jun 27, 2017
    13
    4:00 PM
    Thanks a lot DutchMuch
    Sent from my Moto G (4) using Tapatalk
  4. DutchMuch
    Mar 8, 2017
    1,033
    385
    10:30 AM
    np, when i started out my fluval i had alot of that "Dust algae" as i called it, it went away after a while once i upped my ferts (certain amounts of each) and experimented with lighting.
  5. Ganesh
    Ganesh New Member
    Jun 27, 2017
    13
    4:00 PM
    I am using 30w led flood light. And my dosing per week Ppm levels n- 27.78, p - 2.85, k - 29.7
    Lights are on for 7am to 12pm and 4pm to 9pm.
    What should i do now? Should i remove the leaves affected?
  6. DutchMuch
    Mar 8, 2017
    1,033
    385
    10:30 AM
    i wouldnt but when new healthy unaffected growth appears, and is a good length or height. I would trim that off and replant those good healthy stems.
  7. Pikez
    Pikez Rotala Killer!
    Staff Member Moderator
    May 12, 2013
    1,884
    1,261
    10:30 AM
    Reduce: light intensity and duration
    Increase: water change %, water change frequency, CO2 levels, trimming, cleaning.
    No need to identify algae unless you have a botanical interest in algae. Focus on plant growth, not algae. Anything that causes reduced plant growth will promote algae. The more you focus on algae, the more mistakes you make. Shape and size of new leaves suggest likely CO2 deficiency.
    Greggz and Ganesh like this.
  8. Ganesh
    Ganesh New Member
    Jun 27, 2017
    13
    4:00 PM
    Thanks. I am giving 1 bps co2. And its just 1ft cube tank. Doing water changes as per EI method. 50% weekly. Should i do more water changes?
  9. Ganesh
    Ganesh New Member
    Jun 27, 2017
    13
    4:00 PM
    Thanks.
  10. TheWizard
    TheWizard New Member
    Jun 29, 2017
    5:30 AM
    The best tip I've learned so far is you can have high CO2 and high O2. Surface agitation is your friend.
    Ganesh likes this.
Tags:
