First time poster here and hi to all.
I have been planning a 8'x2'x2' 240g as room divider, view-able on three sides. These are my thought so far, please help to improve it. I live in California low desert, so plenty of sun all the time.
Low tech
Why low tech? I travel a lot and totally inspired by Tom's thread here on how low maintenance low tech tanks can be. As I don't mind buying matured plants, slow growth isn't really a concern. Energy consumption is a concern, using less a welcome bonus.
Tank
Leaning towards glass as I am planning to use onxy sand, and I would like a bigger opening top too.
Substrate
Onxy Sand as recommended by Tom.
Lighting
240g even at 1.5wpg means 360W. I am thinking of using solar tube for day time lighting and a few hours of LED for the evening. Something like these:
Except 2 instead of 4 tubes and not extended so they will be closer to the ceiling and about 5-6 ft from the top of the tank. Not sure if it will provide enough light? I can put 3 tubes of course. I have solartube in my house and they are pretty bright .. standing right beneath, each of them feels like a 150w bulb ... How does one calculate WPG when it comes to LED?
Filtration
Using two Nu-clear or Ocean-clear filters, one for mechanical and the other bio. After reading various forums, leaning towards Nu-clear for its clamp type closing and locking. Planning on using either 950gph or 1200gph pump. Not sure to use them submerged or not though.
Automation
I think I can automate the drain or backflush function of Nu-clear filter to perform a scheduled once every other day of mini water changes. The water from the tank will be used for irrigation of out door potted plans. I live in the desert, those plants need very frequent water to stay healthy, I figured that I need about 12 gal or so every two days. So by doing that, I will be changing 5% of the water every other day. I have found a controller for this automation that has wireless connection so I can even do it remotely.
Refill of water by float valve, an overflow to prevent spillage.
Plants
As Tom said, one can grow all kinds of plans under low tech no CO2. Just that they grow very slowly.
That's what I have so far, thoughts?
Low tech
Tank
Substrate
Lighting
Filtration
Automation
Plants
