My Tank:
Size: 48" X 24" X 18"(ht). arnd 80 Gals.
Lighting: 6 bulbs T5HO in 2 aquasonic fixtures (4 + 2) which is as good as having no reflector. 4 Bulbs run most of the time. 8" from the water surface.
Substrate : ADA AS covered with River Gravel in most areas. only AS in the foreground.
Fertilizer: EI dosing.60-80gal
Filter: Eheim Pro 3 2075, Aquaball internal filter+ Koralia 1050 GPH circulation fan.
Co2 : Pressurised and injected through a ISTA MAX Reactor. Drop Checker Always kept yellow green.
Ok so i have these T5HO fixtures with 6 X 54 bulbs over my tank i bought them because i need the spread as i cannot raise them. The Co2 is kept some what stable and the drop checker becomes yellow green around 2hrs after lights on but i have noticed all my plants pearling only when all the 6 bulbs are on. With 2 bulbs on in the fore ground, only 1 lily near the Filter spray bar pearls. With only the background lights on i get no pearling. Why could this be?
After reading this forums posts i had a feeling that i have too much lighting. But i dont understand if its too much then why does the pearling stop when half the lights are off.
