You're adding sodium aswell, so it's depends on your fish their tolerance for Na+. It's dependand on your KNo3 dose if you will need to add extra K, if you add enough you don't need any extra KS04. Some trace mixes have extra K added aswell, but in most cases that isn't alot.
But why use NaH2Po4? are you aware of an advantage i'm not?
Avaliability. Seems to be harder to come by KH2PO4 here. The company I'm buying from only has NaH2PO4. :/ And ordering from Norwegian suppliers is no go since they either can't be arsed to sell smaller amounts or they're so much more expensive than others. Or both! Going to place an order so I have dry ferts for atleast a year.
@dutchy: Well that settles it then, not getting NAH2PO4.
K+ is dosed as a part of GH Booster already... Well, but most people say
KNO3 alone provides enough K+. So I can't answer this question because
I supplement K2SO4 too, to dose same PPM of K+ and NO3.
PO4 dosage is pretty low, so may be not adding enough sodium to do any harm, but this is just my thinking/guessing, and I have almost no knowledge about this.
It may be quite different if you were going to add NaNO3, a lot more of potential harm.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
