  1. Dismiss Notice
mystery with ph meter electronics
Discussion in 'CO2 Enrichment' started by osmar amaral, May 11, 2014.
  1. osmar amaral
    osmar amaral Junior Poster
    May 27, 2012
    26
    1:58 PM
    bought a ph meter electronics, but I have a problem.
    the meter works fine, but after some time with the lights on, the device shows error, it only happens after a few hours of lights. When I turn off the lights, he returns to work
    if I collect water from the aquarium with a glass, and measure the water in the glass, it works, but if I enter the aquarium of error. ?????????
  2. rjordan393
    rjordan393 Guru Class Expert
    Mar 5, 2013
    197
    1:58 PM
    It appears that the issue may be heat related because the error does not occur until the lights are on for some time. If the problem is electrical, then make sure that the pH probe is not fully submerged. The rubber boot on top of the probe is not to be wet nor the wire above it. You can also try raising the lights or installing an exhaust fan to remove the heat from your lighting fixture. You can also try moving the pH probe to other areas of the tank or placed in the sump if you have one.
  3. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    1:58 PM
    many ph meters are impacted when the lights are on, though this usually occurs as soon as the lights are turned ON and lasts until they are OFF.
    Yours sounds unusual in that it takes several hours. Check the heat as per the suggestion above.
    When I used mine I saw the ph drop .3 when lights came on so I subtracted that from the value displayed and went with that value instead.
    Hope this helps.
    - - - Updated - - -
    Hope this helps.
  4. osmar amaral
    May 27, 2012
    26
    1:58 PM
    the only certainty I have is that the meter is being influenced by light.
    if I take the aquarium water with a cup, and then immediately measure the pH, it works perfectly fine and the temperature remains the same.
