My water has tea color
mr_convitbau
Feb 13, 2009
12
I have AquaSoil Amazonia II as substrate.... dosing is EI method in which I use chelated iron as supplemental.
My water has tea color which is kinna yellowish... Is there any explanation for that and how to make the water colorless again???
thanks a lot...
thanks a lot...
Best guess is the iron supplement stuff.:)
No harm, if it bothers you a couple of big water changes then don't use the iron stuff. I would use CSM+B for iron.;)
I have never used AquaSoil Amazonia II (or I for that matter), if it is mimicking the Amazon basin then it likely is going for that 'black water' look, which means peat moss. If that is the case, I think that is pretty much the look.
I hope this helps.:eek:
Philosophos
1,346
The #1 problem with ADA is they don't tell you what's going on. Before it was horrendously cloudy water, now it's tea colored. I don't mind mistakes, but a company should at least be decent enough to disclose the cause of its faults so that the hobbyist can try to find solutions.
The conjecture mill is saying purigen will clear your water (sometimes). I have a feeling any old microsieve will do, though. The bad news is that it may make NO3 dosing interesting. You could also try flocculants; I've gotten tannins out of the water that way before.
I doubt it's the iron, but you never know. If you can establish .1-.2ppm of Fe with your trace or better, try skipping it after your next water change and see if the staining becomes more intense.
Personally I'd contact an ADA rep and inform them of your problem now, so that you have a foot in the door for a replacement or refund. No decent company would refuse that sort of thing; you pay a premium for their products, and they should work within the parameters stated.
-Philosophos
