The quality is quite evident when you actually hold the parts. This fabco valve makes the clippard feel like a bad joke.
Gerryd;64441 said:Sweet setup....Post more pics when in use![]()
Matt F.;64453 said:Fred,
You can use part #9+10 together:
Swagelok Tube Adapter (locking):
For 4mm (ID)/ 6mm OD tubing (these parts work together to lock the hose on the barb):
B-6MO-1-2
and
B-6M5-4m
OR
You can use a JBJ bubble counter, but you'd have to configure the post body a bit differently.
Specifically,
You'd have to get (from the Fabco NV):
Swagelok B-2c2-1/3 (this has male threads unlike the B-2c4-1/3)
JBJ bubble counter
I use ADA glass in-line bubble counters when using tube adapter. This is a superior system as far as quality goes. This system eliminates the often faulty JBJ bubble counter.
fjf888;64456 said:Matt thanks. That makes a lot of sense, that bubble counter will fail without question.
Is this the counter you are referring to?
http://www.adgshop.com/Glass_Bubble_Counter_p/102-201.htm
I hope you weren't talking the beetle counter it is $125.
My only concern is I use an atomizer inline with my wet dry, which creates a fair amount of back pressure, I would think that could shatter the glass (assuming its put on the right way of course)
I think I will go with the 9-10 parts, why put a piece of crap on otherwise good system.
Thanks again
Matt F.;64952 said:Here are some configurations that will work for your VTS (look at Post#1 specifically):
http://www.barrreport.com/showthread.php/8332-Basic-Swagelok-Parts-needed-for-90*-and-VTS-Builds
Here is where I buy my 3" long w/ filter CGA320 nut/nipple:
http://www.regulatortorchrepair.com/store.php/products/cga-320-nut-and-nipple
great service. they also rebuild regulators.
fjf888;64989 said:thanks Matt, ordered the CGA nut,
Gotta build this thing, suffered EOTD again, caught me by surprise, fortunately I was home and no permanent harm done. So all my parts are ordered should have everything by 5/9. Now to get that other CGA nut off.
This is something some people learn after the CO2 cylinder has emptied too soon. You know about it from the "get-go" and you don't have to worry about it.fjf888;65226 said:... I found after I checked the CGA nut I could tighten it some more. It seems no matter how hard I think I have something tightened, I can always come back an hour later and get a little more turn.
Left C;65206 said:The general rule that I follow is for Teflon tape on the high pressure parts and non-hardening Teflon thread sealer on the low pressure parts. Matt prefers more Teflon tape than I do. The main things to be concerned with is that no Teflon tape can break off and keep the solenoid from closing and the other is to not have any CO2 leaks. When you tighten the regulator to the CO2 cylinder, use a washer, of course, and to really tighten it down. Then come back and see if you can tighten it some more. Be sure to use the "big arm" on it.
Have you seen the MK II Perma-Seals that do not have the screw on part? I'm not sure if they are still made.
