My RO water still has 10ppm TDS - What is it?
Tom Wood
139
Kerrville/Austin, Texas
I'm still not getting a good response from the plants, even after going to 100% RO water.
My water starts as 510ppm, 24Gh, 16KH, that also goes through a whole-house salt-based water softener before being processed by the RO unit. The end result is 10ppm TDS. But I read here:
"Purity is determined by two things, first the "reject ratio of the membrane (92-99.5%) and secondly, the type of salts in solution. Membranes are very good at rejection high molecular weight compounds and multivalent ions. Monovalent ions such as Na+ and Cl- (Sodium and Chloride) are not rejected as well and are the leakage ions."
http://www.remco.com/ro_quest.htm
So, if that 10ppm remaining in the RO water is all sodium and chloride, is that too high a level? I can add a DI unit if needed, but if this level is not likely a problem, I won't bother.
TW
780
Re: My RO water still has 10ppm TDS - What is it?
10ppm is not much and given the starting water also.
Simpte
Feb 17, 2005
76
Temperature also plays a part in the units effectiveness. I believe R.O. units work best when the water temp is 78 degrees. Any hotter or colder and they don't run as efficient. Not the a degree or 2 will have any noticeable effect but you get the idea.
trcpdx
17
Portland, OR
Tom - how are you measuring? Just read something about the accuracy of TDS meters. Seems a meter with a range of 0-999ppm and a rated accuracy of +/-2%, might have an error range of +/- 20ppm. That 2% could be 2% of the full scale!
Tom Wood
139
Yeah, it's a cheapo TDS meter that I bought with the RO system, but it's the best I can do. I was really more interested in an order of magnitude feel for the end result anyway, rather than an absolute value.
TW
trcpdx
17
Portland, OR
TW
So maybe your TDS is really zero! :)
