This is my first post here.
I'm putting up a planted tank at work.
The tank is 47x16x20inch (120x40x50cm)
240 liter (63 galon)
Eheim 2217 external filter
Pressurized C02 with external reactor.
Light. 4 T5 39W with reflectors.
Planning on using PMDD with a dosing pump system.
Substrate. cat sand and blaster sand.
The thing is I would like a quite low maintenance tank and have a few questions.
EDITED! The tank will be high tech. So what I mean is as low maintenance as possible but still high tech.
What style and plants will work best for low maintenance?
Do I have to add something to the substrate?
How to startup? I read something about starting the plants without water?
I'm planning 30-50% water change once a week. Is that ok?
CO2 bubble rate. What should I start with?
Should the CO2 be on the same time as the light or should I put the CO2 on a separate timer? (Light 10hrs/day?)
I'm using a tripple dosing pump for the fertilizer. Should I fertilize once per day or...?
Well, lots of questions
Cheers,
Patrik
Cheers,
Patrik
