My Emersed Aquarium Plant Rack
Discussion in 'Journals' started by Jason King, Mar 2, 2015.
  1. Jason King
    Jason King barrreport.com
    Nov 20, 2011
    1,575
    364
    11:20 PM
    Hi all
    My last setup was going great with daily routines of misting and daily maintenance but due to more important personal things and being away from home i lost a few plants.
    Lack of these daily chores has made me setup a more advanced system that will allow me to leave my setup to run itself for a while without losing my plants.
    Ok so my setup is in my garage this will also allow me to go bigger allowing me to keep a lot more than one tank.
    As multiple tanks will cost me a lot I've decided to use RUBS (really useful boxes)
    A list of my setup plans:
    4x Shelf Rack 1800W × 1800H x 600D
    12 x RUBS - 3 shelves of 4 RUBS all plumbed as one system.
    1 X Pond Filter that has a built in uv light.
    1 X Sump and Pump to the filter on a higher location.
    3 x t5 lighting, 1 for each shelf 9 some now have 2 per shelf)
    2 x aquarium heaters in sump to raise water temp for humidity, this will also prevent freezing water in the winter as the setup is in the colder garage.
    1 x Air stone in sump
    Based on the rub sizes each rub will allow me to have 15+ x 3" pots of plants x 12 rubs = 180 pots :eek:
    A bit over the top maybe but that was my plan.
    [​IMG]
    The plant list is just for reference and has changed slightly.
    also i probably did not need the pond filter and its maybe over the top? but i already had it doing nothing so i integrated it into the system as ill be adding some shrimp to the setup and the uv will help with green water?
    some images to give you an idea of the setup
    some random pictures to give you an ideas of equipment i used
    Industrial Shelving With 5 Shelves, 1780h x 1800w x 600d mm 265kg UDL
    [​IMG]
    The Filter
    [​IMG]
    [​IMG]
    Floplast 21.5mm over flow fitting as these are cheaper than 22mm and its easier to fine 40mm(filter & pump) to 21.5mm reducers etc
    [​IMG]
    The pump
    [​IMG]
    Features:
    Dimensions: 153 x 105 x 135mm / 6" x 4.1" x 5.3"
    Height Max: 350cm / 137.8" - Cable Length 5M
    Flow rate: 3000L/h
    before the plumbing
    [​IMG]
    12 RUBS, 24 tank connectors Later
    [​IMG]
    Plumbed
    [​IMG]
    The sump,pump and overflow(just in case [​IMG])
    [​IMG]
    Flow from rub to rub.
    [​IMG]
    Shallow rub on the next level.
    [​IMG]
    an idea of some 80mm high pots in place.
    [​IMG]
    Here are some random pictures of the plants etc.
    [​IMG]
    [​IMG]
    Some of my Crypts
    [​IMG]
    The plants
    [​IMG]
    Anubias
    [​IMG]
    Some of my Stems
    [​IMG]
    Crypts
    [​IMG]
    random shots
    [​IMG]
    PEARL MOSS / PLAGMONIUM SP. (this has grown a lot more since this picture was taken a week after i tied it to my home made moss pads)
    [​IMG]
    here you can see how slow/fast the water trickle is that circulates from rub to rub then onto the sump and filter
    [​IMG]
    New growth from Anubias heterophylla that is using 50/50 clay balls/rockwool substrate
    [​IMG]
    And the easy to grow Hygrophila polysperma
    [​IMG]
    some of my plant labels
    [​IMG]
    plants that are currently in the setup are:
    Amblystegium serpens 'Nano'
    Anubias barteri angustifolia
    Anubias barteri var. barteri
    Anubias barteri var. caladiifolia
    Anubias barteri var. nana
    Anubias gracilis
    Anubias hastifolia
    Anubias nana
    Anubias nana "Pinto"
    Anubias nana Bonsai
    Barclaya longifolia
    Blepharostoma trichophyllum 'Mini Rose'
    Blyxa japonica var. alternifolia
    Bolbitis "spec" Baby
    Cryptocoryne amicorum
    Cryptocoryne beckettii
    Cryptocoryne bullosa
    Cryptocoryne costata
    Cryptocoryne legroi
    Cryptocoryne moehlmannii
    Cryptocoryne nevellii
    Cryptocoryne nurii "Rosen Maiden" Bt.Perah
    Cryptocoryne parva
    Cryptocoryne petchii
    Cryptocoryne undulatus brown
    Cryptocoryne undulatus kasselman
    Cryptocoryne walkeri
    Cryptocoryne wendtii "tropica"
    Cryptocoryne wendtii brown
    Cryptocoryne wendtii green
    Diodia cf kuntzei
    Drepanocladus 'Flat'
    Eriocaulon cinereum
    Fissidens fontanus 'Phoenix'
    Fontinalis antiperytica var. Gigantea 'Giant Willow'
    Fontinalis hypnoides 'Quell Willow'
    Frontinalis antipyretica 'Willow'
    Hygrophila araguaia
    Hygrophila balsamica
    Hygrophila corymbosa Siamensis 53B
    Hygrophila corymbosa thailands
    Hygrophila guanensis
    Hygrophila Lancea
    Hygrophila odora 'Guinea'
    Hygrophila polysperma 'Ceylon'
    Hygrophila polysperma 'Tiger'
    Hygrophila Purple
    Hygrophila Roraima
    Hygrophila rosae australis
    Hygrophila 'Sarawak'
    Hygrophila sp. 'Bold'
    Isopterygium 'Mini Taiwan Moss'
    Leptodictyum riparium 'Stringy'
    Lilaeopsis brasiliensis
    Lilaeopsis mauritiana
    Lomariopsis 'Subwassertang'
    Phoenix Moss 'Fissidens Fox'
    Plagiochilaceae 'Cameroon'
    Plagmonium 'Pearl'
    Polygonum sp. 'Ruby'
    Riccia fluitans
    Staurogyne rubescens
    Taxiphyllum alternans 'Taiwan'
    Taxiphyllum barbieri 'Java'
    Taxiphyllum barbieri 'Mini Java'
    Taxiphyllum 'Flame'
    Taxiphyllum 'Giant'
    Taxiphyllum 'Peacock'
    Taxiphyllum 'Spiky'
    Trithuria Sp Erio Blood Vomit
    Vesicularia 'Anchor'
    Vesicularia 'Brazil'
    Vesicularia 'China'
    Vesicularia 'Creeping'
    Vesicularia dubyana 'Singapore'
    Vesicularia montagnei 'Christmas' (dubyana?)
    Vesicularia reticulata 'Erect'
    Poaceae sp. 'Purple Bamboo'
    Staurogyne Low Grow
    plus various rotala species
    ill update this over the next month or so with photos of plants and blooms
    DeepMetropolis likes this.
  2. Monk
    Monk Junior Poster
    Feb 28, 2015
    23
    11:20 PM
    very nice!
  3. Donald Cutler
    Donald Cutler Junior Poster
    Feb 27, 2015
    17
    6
    11:20 PM
  4. BBogdan
    BBogdan Junior Poster
    Mar 1, 2015
    31
    13
    11:20 PM
    very nice and interesting ;)
  5. Dennis Singh
    Dennis Singh SynKing!
    May 5, 2013
    2,417
    639
    3:20 PM
    Very nice, emmersed is a great way for those brown thumbs, very easy to grow "some" emmersed plants, as well non-maintenance stuff. I like your elaborate setup though, looks like you put a lot initial work in...
  6. ghostsword
    ghostsword Lifetime Charter Member
    Feb 3, 2010
    77
    11:20 PM
    Really nice setup.. :)
  7. Dennis Singh
    May 5, 2013
    2,417
    639
    3:20 PM
    Jason, Have you tried growing emmersed in natural sunlight? With emmersed setups I don't see why people add light to their setups...or pumps or so on lol which you have done. Emmersed should and can be the lowest possible tech there is...(natural sunlight [be sure to shade your plants] so actually indirect sunlight), soil and moisture...Nonetheless, you should be commended on such a great setup that you have...Just a suggestion that you can go even lower and lower in technology for emmersed plants.
  8. Jason King
    Nov 20, 2011
    1,575
    364
    11:20 PM
    Yes i have and I agree with most things you've said, but the thing is in the UK the tempurture is currently 0 degrees, the last two days we have had snow.
    Last year my plants outside died due to this.
    The reason for my setup is just that to keep the temp up and stop the plants from freezing.
    If I was in say California or south Africa I would proberly of not gone for this setup.
    The filter is proberly not needed but I had it in the garage doing nothing.
    The pumps help stop the water going stagnant.
    The reason I plumbed all the rubs together was because I only need 2 heaters in the sump and not 12 ( one for each rub)
    Sure I would of liked to just place the setup out side without all the tech but in the UK winter this does not work, up north anyway.
  9. Dennis Singh
    May 5, 2013
    2,417
    639
    3:20 PM
  10. Jason King
    Nov 20, 2011
    1,575
    364
    11:20 PM
    No not at all :)
    Just showing you the reasons ;)
  11. SwampGremlin
    SwampGremlin Member
    Jun 1, 2015
    271
    32
    11:20 PM
    Would be very fun to rescape with all of that to choose from. Cool stuff
  12. Joe Ader
    Joe Ader New Member
    Mar 20, 2019
    7
    6:20 PM
    Wow
    Love Your Setup
    Very Very NIce
    Happy Day
    Jason King likes this.
  13. DeepMetropolis
    Nov 9, 2017
    114
    85
    12:20 AM
    Really nice, wish i had a garage.
  14. jbs47
    jbs47 Lifetime Members
    Mar 12, 2015
    89
    28
    11:20 PM
    Great set up...plants look like they are loving it.
