My CO2 and gassing fish management plan - Am I doing okay?
Discussion in 'General Plant Topics' started by plantsgallery, Mar 6, 2015.
  1. plantsgallery
    plantsgallery Junior Poster
    Nov 29, 2014
    15
    2:08 PM
    Hi, folks, I can still see deficiency just like same one as I posted before.
    Progressively smaller new leaves, stunted growth and weakened lower leaves... Thanks to EI, now there is only one suspect. Hight light with low CO2.
    It seems that my light has reflectors in it, so the PAR meter of it is higher than I think.
    I'm trying to add more CO2 and only see fish panting. Maybe my lily pipe doesn't make enough surface agitation , so I decided change it with poppy pipe which shoots flow toward surface.
    And more flow with bigger filter.
    Before new pipe arrive, to keep a balance between light and CO2 temporarily, I made temporary light screen with A4 paper. :eek:
    This will reduce light and make 'low light + rich CO2' situation.
    I wonder I'm heading correctly.
    Thanks.
    [​IMG]
    #1 plantsgallery, Mar 6, 2015
  2. jerrybforl
    jerrybforl Lifetime Members
    Mar 7, 2010
    1,034
    2:08 PM
    Becareful! You are treading on thin ice with that. Light is the engine that drives your tank. If you block it and add more CO2, you will have issues with your critters. Do you have a PAR meter to get readings?
    If you lower the light, you should lower the CO2.
  3. SouthFL
    SouthFL Junior Poster
    Mar 15, 2015
    2:08 PM
    Mine I have the opposite problem, low light and high co2. If I double up on my LED lights will it give me double the PAR?
  4. Simon Yee
    Simon Yee New Member
    Premium Member
    Apr 3, 2019
    9:08 PM
    Pardon to bud in
    Question:-- What is the best and cheap PAR meter?
  5. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    2:08 PM
    These are the symptoms of Zn deficiency, though many variables can induce -Zn. Eg. excess Pi, Fe, Cu, B, etc. -Zn cannot be alleviated by adding more CO2.
  6. Tim Harrison
    Tim Harrison Lifetime Member
    Jul 7, 2017
    336
    297
    2:08 PM
    Can you post some pictures of your tank and the plants, it might help diagnose what's wrong.
