I'll try not to spatter my stuff around as much and put everything here. I don't have the tank yet (eta Jan 4) so I'll summarize everthing I've decided for now and post pix as I get them.
The tank is a nominal 90g (48Lx24hx18d), 3/4" Starphire rimless with the "back" bottom corners drilled and fitted with 1.5" bulkheads. All plumbing is underneath the tank driven by a Velocity T4 pump, View attachment 2016
Filter is a Nu-Clear 522 canister with carbon removed and replaced by Eheim Substrat Pro. Heater is ETH300. CO2 is 20lb tank into two stage regulator, Clippard mouse solenoid and either a NV55 or a simple barb if the mouse is pulsed; check valve of course. Reactor is 20"x2" DIY. Light is Catalina 4xT5HO switched to allow 1,2,3 or four bulbs to be lit. Normally only the two outer bulbs will be lit with 6500K. Light mounted atop legs over open top tank.
Plumbing is done as follows in words, diagram when I can find a suitable tool eventually:
Bulkhead (BH) 1.5" -- Ball Valve (BV) 1.5" -- Union (U) 1.5" -- Reducer 1" -- FlexPVC 1" -- T4 Pump input (mounted vertically)
T4 Pump out -- Flex 1 -- BV 1 -- U 1 -- Canister In
Canister Out -- U 1 -- Manifold Y 1x1x1
Main line from manifold -- BV 1 -- Flex 1 -- Manifold Y 1x1x1.5 -- Long radius 90 elbow upwards 1.5 -- U 1.5 -- BV 1.5 -- Return Bulkhead 1.5
The other line from the 1x1x1 Manifold feeds the vertical heater/co2 siding as follows:
From the manifold:
Flex 1 -- BV 1 -- 5/8" barb -- 5/8" hose -- ETH300 -- 5/8" hose long radius 180 -- input on top of reactor
Reactor out -- Flex 1 -- U 1 -- BV 1 -- other input of combining Manifold 1x1x1.5.
This arrangement allows removal of canister if desired for service if necessary. Also allows for removal of CO2/heater and still run filter.
Flow will divide at 1x1x1 manifold Y into direct return and siding legs with flow limited naturally by 5/8 restriction at ETH. Flow will be recombined from siding and main line via 1x1x1.5 manifold.
Long radius 1.5 PVC elbow limits loss and is the only major turn on the main loop. Only slight alignment bends made by FlexPVC will exist on main loop. The initial big vertical to horizontal turn is done by vertically mounting the pump. Horizontal pump output in this arrangement naturally aligns with the canister input.
I'm sure all this will be much clearer in a diagram.
Stand is a 2" sq tubular welded steel topped with 3/4" plywood covered with a 1/2" sheet of homasote as a buffer. Stand interior bottom to be 3/4" plywood.
Stand exterior will be four separate cherry face frames finished in tung oil, magnetically attached. Google Sketchup here: http://sketchup.google.com/3dwarehouse/details?mid=a50dae8b9f6fc4e76f5eed2f86cabe38
Tank inlet flow to be managed via Loclines, TBD. Tank outlet flow 6"x1.5" strainer.
Substrate MTS capped with Florite Black Sand. Mineralizing starts 12/19/10! Woo hoo! Followed by a month or so of DSM.
Drain via hose to outside and fill via showerhead fitting. The usual PVC over the tank edge siphon cut for 25% length used for WC. Full tank drain or plumbing drain via hose fitting on Nu-Clear.
Flora, fauna TBD.
Comments and suggestions welcomed.
Jim
From the manifold:
Flora, fauna TBD.
Jim
