Muriate of Potash and KCl
Discussion in 'Advanced Strategies and Fertilization' started by ATM, Oct 5, 2017.
  1. ATM
    ATM New Member
    Oct 5, 2017
    1:24 PM
    Is Muriate of Potash and KCl one and the same? I tried using the Nutrient Dosing Calculator v1.5.9 in rotalabutterfy.com using the Muriate of Potash and Potassium Chloride (KCl), but they yield two different results.
    Also, there is a warning "The solubility of K at room temperature is N. You should adjust your dose." What is the meaning of N in the statement and what should be the right adjustment?
    #1 ATM, Oct 5, 2017
  2. Pikez
    Pikez Rotala Killer!
    Staff Member Moderator
    May 12, 2013
    1,884
    1,261
    5:24 AM
    Yes, Muriate is Chloride. Don't use it - adds too much chloride and you get all the potassium you need from KNO3.
    So, go with KNO3 (potassium nitrate) or K2SO4 (potassium sulfate) instead.
    @fablau - rotalabutterfly issue...
  3. ATM
    ATM New Member
    Oct 5, 2017
    1:24 PM
    Thanks. Unfortunately, I could not get KNO3 or K2SO4 in my place. Also, I am trying not to dose Nitrate and see if I could control my Algae better. I read in some other forum, that Chloride is not bad, if not in large quantity. I am just confused on what compound to put on the calculator, using KCl and Muriate of Potash yield different results. I do not know where to base my dosing. Thanks a lot for the info, anyway.
  4. fablau
    fablau rotalabutterfly.com
    Sep 13, 2008
    2,615
    475
    9:24 PM
    Thanks for the heads up, I have checked and they give different results indeed... fact is, Zorfox's calculator is giving the same exact results. Which element is giving the correct results? The "Murriate of Potash" looks off a great deal...
  5. fablau
    Sep 13, 2008
    2,615
    475
    9:24 PM
    Could you please give me the values you have entered to have that warning showing up? Thanks :)
  6. ATM
    ATM New Member
    Oct 5, 2017
    1:24 PM
    fablau :
    Yes, using Muriate of Potash as the compound, it seems to be off as compared to other readings I've done and other videos I watched. Using KCl seems to be okay.
    These are the data that I used in the calculator that gives the warning:
    55 US gal
    DIY
    Muriate of Potash
    A Solution
    500 ml
    6 ml
    EI daily
    Auto
  7. ATM
    ATM New Member
    Oct 5, 2017
    1:24 PM
    Is the Chloride part of KCl safe?
Similar Threads - Muriate Potash KCl
  1. tomotomotomo
