Hello folks,
I have begun EI dosing 10 days ago, and I must say that I am not really impressed with the results so far. I haven't noticed any significant improvement in my plants overall, and instead some sort of deficiency issues appeared on some as I mentioned here:
http://www.barrreport.com/showthread.php/13322-Moving-into-EI-is-this-my-first-sign-of-deficiency
While the above signs seem to start fading, most plants haven't gotten much better than before. Instead some leaves are getting some pin holes and others, Marsilea Minuta, are turning yellow (!!!). Never had this signs before when I dosed 4 times less. My thinking is that plants are adapting to the "new environment", but of course I can't bet on that.
Also, with my last water change 2 days ago, I cleaned my glass as usual, and I have noticed that some brown algae (probably diatoms) appeared on my glass. That never happened before, and I haven't changed anything about light or Co2. Just moved into EI fertilization.
Is that a sign that my light is lower than the nutrients I am putting in the tank?
I have a 75gl tank. My lights are T8 fluorescent lights, 160w 8 hours a day. Since I know I don't have high light, I am currently dosing EI as if I had a 60gl tank.
I plan to buy a Par meter, so I will be able to better understand my light situation soon, but in the meantime, any thoughts about this diatom issue or plant growth signs are very welcome!
Thanks in advance to anyone.
