I have learnt that fish heading to the surface when using CO2 enrichment does not necessarily mean "I have enough CO2".
Plenty of beginners with CO2 enrichment often comment something like "it can't be that I don't have enough CO2 because if I turn it up any more the fish head for the surface".
More likely it is because the dissolved oxgen levels in the tank are not high enough (beginners also of the mindset that the surface of the water should be absolutely still).
Ok, so I have a good surface ripple going.
But after a few hours into the CO2 enrichment period, fish start coming to the top, starting with the tiger barbs (high O2 requiring species).
By the next morning the fish are all swimming around normally again (i.e. the problem goes away temporarily; thereby ruling out anything else that might be in the water that would cause them distress).
Too much CO2 really just means that the fishes ability to capture oxygen in their blood is horribly impared as opposed to the CO2 directly harming the fish?
So it makes sense that getting the maximum amount of O2 in the water would be the aquarist's perogative, and then gradually add the well distrubted CO2 until the plants are growing well.
My tank is moderately stocked and I have 2 canister filters, so I guess the BOD (Biological/Biochemical Oxygen Demand) is reasonably high...
My indicator plant (H.Polysperma) doesn't do so well if I turn the CO2 down, but I don't seem to have any other means of adding more O2 to compensate (I already have a good surface ripple as mentioned earlier).
I guess this is where a sump and it's open nature (as opposed to closed canisters) gives you much more improvement?
Sump users that also have a DO meter, would I be correct in assuming that your DO levels are always very good? Therefore this perogative is met; you can then add as much CO2 as you like? Can you still overdo CO2 using a sump?
Scott.
P.S. I know water temperature plays a huge part too; here is Australia it is warming up now, my tank getting above 30 degrees celcius some days. I wonder if my tank simply cannot hold any more O2, perhaps it's saturated with O2 but that's still not enough? Are there any inexpensive ways to test O2 levels?
Scott.
