Mix salts with traces?
Discussion in 'Estimative Index' started by Piotr Tomaszewski, May 7, 2015.
  1. Piotr Tomaszewski
    Piotr Tomaszewski New Member
    Jul 4, 2014
    14
    2:09 AM
    I have read in one of the posts here that tropica liquid fertilizer is good to use for traces. I have now one dosing pomp where I use tropica micro and macro fertilizer. I am thinking about switching to EI and keeping tropica as source for micro. Do you think I could run into problems by mixing tropica fertilizer with macro salts from EI recipe? I need to use dosing pump when I am away. Cost of another dosing pump will probably not justify switching to EI.
  2. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    2:09 AM
    There shouldn't be any problems. Tropica, and all other liquid fertz companies, use dry salts and metals and dilute with water and package it into a bottle.
  3. Kathy Yata
    Kathy Yata Junior Poster
    Mar 15, 2015
    34
    2:09 AM
    There is a possibility that phosphate will bind iron into an insoluble compound if the two are mixed. That is why micros and macros are alternately dosed in the first place in EI. There is a way to insure that won't happen, something about the pH level of the solution but don't just dump all the nutrients together in the proper ratio and expect it to work out.
  4. Piotr Tomaszewski
    Jul 4, 2014
    14
    2:09 AM
    There's already some phosphate in Tropica product, so I expect chelates have the right quality
