Mitras Lightbar Ocean Blue for freshwater? (with Spectrum pics)
Discussion in 'Lighting' started by Gilles, Sep 2, 2014.
  1. Gilles
    Gilles Lifetime Members
    Aug 6, 2008
    645
    12:38 PM
    So i currently have 2x Mitras Lightbar Daylight on my tank and i am thinking on adding a third tube.
    The question i have is; should i go for another Mitras Lightbar Daylight or for a Mitras Lightbar Ocean Blue as third tube?
    Mitras Lightbar Daylight (current LED light)
    [​IMG]
    LED-configuration per 10 cm Lightbar:
    5 color channels:
    2 x Cree XBD 6500 K
    2 x Cree XBD 4500 K
    4 x Cree CLV6A, red 622 nm, green 530 nm, blue 472 nm
    Mid color temperature: 5500K
    Luminous flux per 10 cm Lightbar: 486 lm
    [​IMG]
    7 color channels:
    1 x Cree XBD royal blue 455 nm (not in daylight)
    1 x Cree XBD 8000 K (not in daylight)
    1 x Cree XBD 6500 K (same as daylight, only 1 LED less)
    1 x Cree XBD 4500 K (same as daylight, only 1 LED less)
    4 x Cree CLV6A, red 622 nm, green 530 nm, blue 472 nm (same as daylight)
    Mid color temperature: 9000K
    Luminous flux per 10 cm Lightbar: 382 lm
    I can tune each LED independently btw, so i can completely shut off the XBD royal blue if needed and only have the "Cree XBD 8000 K" as added benefit.
    #1 Gilles, Sep 2, 2014
