Mission Against HC&Algae. Submerged&Emerged.Cylinder+Excel=Double C02 Final ShowDown!
dna9179
Aug 26, 2009
40
Calcium Sulphate
Magnesium Sulphate
Potassium Nitrate
Mono Potassium Phosphate (also known as Potassium di hydrogen Phosphate) K2SO4 (Potassium Sulphate)
All above 5bag? that all above contain NPK and 2more fert stated above right?
Is Biollante and Philosophos here? Is there any comment to add or advice before i mark the go. :) Hey thanks Nipat too :)
Philosophos
1,346
I'll start off with addressing macros here.
If you can get K2SO4 in Singapore, then do so. If not, you can probably top off the missing K+ with Seachem's Potassium. The 4 compounds you have listed there do not cover for the extra potassium needed on top of what they provide.
If you can't get any of those chemicals, you can use Seachem's Equilibrium, then top it off with Flourish K+ and Flourish N. I would not use this this method if you have hard water; I used to post over on AQ more frequently, and I know SG water varies a lot.
If you want to use Tropica Plant Nutrition, you can dose 75ml a week and then top off your K+ with some K2SO4 or Flourish K+. This will take care of everything in the most simple way, but is probably the most expensive route. If you have soft water, you may need some CaSO4 or CaCl2 to raise the calcium.
Now, as for micro nutrients...
If you use the first two methods I described, you can use CSM+B, TPN/TPN + or Flourish to accomplish what you need. I prefer CSM+B for price and iron concentrations, TPN/TPN+ used as a micro only works well but I'd use some chelated iron with it possibly. Flourish works on its own. If you can get flourish plus one other type of micronutrient, you can switch between the two to make up for any possible nutrient deficiencies that exist between the ferts and the tap water.
And finally, I looked over the LushGro line. I can't say I like the look of it as well as any of what I listed above, but if there's nothing else available, it's worth a try. The LushGro Aqua would need more N and PO4. The LushGro Hydro Solid looks good (copper levels shouldn't be a problem) but it would need more N and K to make up for its high PO4. The other lines didn't look too worth while to me. Either of these options would probably benefit from some LushGro Trace, or any other trace we've talked about so far.
-Philosophos
dna9179
Aug 26, 2009
40
Hmmm i need to try and read again and understand which u method u will recommend me. At the same time let hope Biollante will be online. I would like to view the comment from 3 of u guys Biollante, Philosophos and Nipat before i decide in which to go. Hope to get the best out of it :)
dna9179
Aug 26, 2009
40
Whooo the Tropica Plant Nutrition is 500ml, dose 75ml a week and it will finish in 6week!? it's quite expensive too the product from ropica Plant Nutrition.
Yes, this is why many folk use CSM+B or another trace.
Tom is currently working on getting his own out to us :)
You can also buy a much larger TPN but will pay much more for it...
It IS an excellent product however and I have had good success with it.
dna9179
Aug 26, 2009
40
I got confuse. U said that is why many ppl use CSM+B or another trace product but i'm talking about the Tropica Plant Nutrition which is providing NPK and not the trace u mention.
Beside dosing Tropica Plant Nutrition (Contain NPK), we still need to dose trace (Plantex csm+b) right? So ...???? kind Confuse by you now...???:confused:
dna9179
Aug 26, 2009
40
I got the catalog with detail the Lushgro is selling
As i'm really confuse and new to this term of Kn03 KH2p04 ect ect ect, i could't understand which item to get from the catalog.
Would u mind helping me in pointing out which item should i can in the catalog to complete the EI dosing?
The catalog is here
thanks thanks
Order
K26
3 x K29
K49
K55
I'd mix the K49 into the K55 product and use that as the trace micro mix.
dna9179
Aug 26, 2009
40
K26
1KG
3 x K29
3KG
K49
100G
K55
100G
Just to check with u, do i need the 1kg for k26 and 3kg for K29?
k26 and k29 both got the 100g and 500g, if i get 100g or 500g will it be enough for the premix dosing? thanks Tom
dna9179
Aug 26, 2009
40
Order
K26
3 x K29
K49
K55
Nipat recommend me to get
Calcium Sulphate - k15
Magnesium Sulphate - k20
Potassium Nitrate - k28
Mono Potassium Phosphate(also known as Potassium di hydrogen Phosphate) - k25
So apart from these 2 set of choices which should i go for ect? is there any different? Why is there 2 different set of fert as i thought getting NPK and trace will be for EI dosing? Thanks for advice. Hope to comes up with a final decision by these few hours so i can go and get the fert in the morning :)
nipat
May 23, 2009
665
Don't you see K25 and K26 are just the same thing, the difference is just bag size?
Also for K28 and K29.
Read more throughly.
PS. I've never told you to buy by K-coding, I just said type of the fert, ie
Potassium Nitrate etc. You're putting words into my mouth.
dna9179
Aug 26, 2009
40
hey really sorry if there is any misunderstanding in my posting. Hope u will't be angry.
I'm try to said the different in Calcium Sulphate and Magnesium Sulphate which u highlighted to me and i look for the K coding and place the K coding there to understand which to get. I know the k25 and k26 as well as k28 and k29 but i'm only try to ask regarding the Calcium Sulphate and Magnesium Sulphate which u mention and the coding from the catalog is k15 and k20.
Hope u dun get so angry and sorry about my posting if it cause misunderstanding. I'm very new to this fert thingy and i know i cause u guys trouble too but i really wish to get everything right and make the right order to feed my plant ... Once again sorry and thanks
What Tom Barr Says.
I think you should do what Tom Barr suggested.:)
  • K26 LUSHGro – Potassium dihydrogen phosphate (1 kg) K2HPO4
  • K29 LUSHGro – Potassium Nitrate (1 kg) KNO3, I know this requires a permit, I think it is just registration. Tom Barr Has recommended purchasing three of these; I think one is good for now.
  • K49 LUSHGro - Rexolin D11 (100 g) Fe-DTPA containing 11% chelated iron
  • K55 LUSHGro - Rexolin APN (100 g)
  • an ideal mixture of all chelated nutrients mentioned above containing 5.8% iron, 2.3% manganese, 1.3% zinc, 1.05% boron, 0.25% copper, 0.24% molybdenum and 0.03% cobalt​
These are ideal chemicals for EI method.
I think you will need to register with the police to purchase LushGro catalog item K29, the Potassium Nitrate (1 kg).
This is for Nipat:
  • If I offended you, I did not mean to, my most humble apology. My comment regarding the CO2 toxicity was unnecessarily abrasive.:eek:
  • I still believe you are mistaken about the dosing of Tropica + Liquid, when I used APC’s Fertilator, http://www.aquaticplantcentral.com/forumapc/fertilator.php, one I think you cite, I came up with nearly identical numbers to what I posted earlier, based on labeling.
  • I think there is enough of a language difficulty here that care should be taken not to further confuse the issue.
  • We can only offer aid, the understanding and decision is solely the responsibility of the recipient.
dna9179
Aug 26, 2009
40
Hey i'm really happy to see u back here, Philosophos is also helping me using PM.
Ok due to budget i will not get the 1Kg of the fert. I will get
LUSHGro - Potassium
Nitrate either 100g or 500g (Kno3)
(i can get the Potassium Nitrate without apply from police only if i get them to premix with others fert and i'm going to get them to premix Potassium Nitrate with Potassium dihydrogen phosphate)
And
LUSHGro - Potassium
dihydrogen phosphate (100 g)
As for the premix, i seek advice from Philosophos too and i will get them to premix both fert in the ration of
33-40g Potassium Nitrate with
7.2g Potassium Phosphate
I will enforced the ration for more, maybe like
494g Potassium Nitrate
93.6g Potassium Phosphate
It's 13times of the above ration.
So far am i correct? :)
[/LIST]
Philosophos
1,346
Actually I was recommending 33-40g of K2SO4 to go with the 33g of KNO3.
-Philosophos
dna9179
Aug 26, 2009
40
Ok i made a mistake...
Alright let do a double confirm again.
LUSHGro - Potassium
Nitrate Kn03 33g
LUSHGro - Potassium
dihydrogen phosphate 7.2g
Potassium
Sulphate
K2SO4 33g-40g.
The above ration will be the final macro premix right? thanks again and sorry
dna9179
Aug 26, 2009
40
getting very sleepy now, i did not sleep throughout the whole night....
the sun is rising now... :)
