MIRO4 vs Coralife reflectors
Discussion in 'General Plant Topics' started by JadeButterfly, Feb 21, 2005.
  1. JadeButterfly
    JadeButterfly Guru Class Expert
    115
    5:36 PM
    My tank is a lil wide, 36"Lx18"W
    and I am using the Coralife 36" 2x96W fixture.
    I was wondering if the Coralife reflectors are any good compare to the well known MIRO4 reflectors...because I feel like the light isn't able to spread out wide enough with my current stock reflectors.
    has anyone able to retrofit MIRO4 reflector from AHsupply into the Coralife fixtures?
    thanks
  2. chubasco
    chubasco Guru Class Expert
    284
    5:36 PM
    Re: MIRO4 vs Coralife reflectors
    The problem wouldn't go away all that much changing to the MIRO4. The
    MIRO4 focuses the light downward, more than it spreads it out over a wide
    area tank. There was a discussion on APC about this where the concensus
    is using NO fluorescents in an expandable reflector which would cover more
    area of the tank. There would be a drop in intensity, tho. Using cf lighting,
    I would go with 2 rows of lower wattage for your tank, say 2x40w or 2x55w each row. Then I would look at the MIRO4 for a retrofit. I've used only MIRO4s, and am not familiar with the Coralifes to judge if they're as good.
    Bill
