I was checking my KH last week with one of those all-in-one strips as I did not believe the readings from my main kit. The KH test was OK, but I noticed a touch of Nitrites. I thought this was strange, since Ammonia was 0 and Nitrates around 10 PPM. I was told elsewhere that low Phophate can interfere with the nitrobacter.
So I tested my Phosphate with my crappy kit and it was the standard piss green/yellow colour, which should be somewhere between .2 and .5 BWTFK. I decided to add about 1 ppm of Phosphate two nights ago and it was back to the standard colour when I tested last night. Although plants seem to have had a busy day. I added another 1 PPM last night and the colour had fallen off again by tonight. The plants don't seem to have grown as much, but there are a ton of leaflets tonight.
As you can probably tell, I'm a Heretic (No EI Yet), so I don't add any NO3 currently, but check it weekly to make sure it's OK. although I do add traces, K and Mg. I would have expected my Nitrates to drop off the charts with all that Phophate being used up. But it's still around it's usual 10 PPM, what's up with that? I did add some Pond tabs to a couple of pots a few weeks ago, but I would have thought the effect would have worn off by now?
