Mine tanks
Discussion in 'Journals' started by nicpapa, Dec 13, 2016.
  1. nicpapa
    nicpapa Guru Class Expert
    Mar 2, 2012
    671
    441
    6:16 AM
    I start a new topic to update mine tanks...
    Here is the first one.
    Its 100lt tanks , one pair ancistrus, and a lot of babies 100-150.
    I had 20rummys , but after i left for 1.5 month i found only four.
    Filter is fluval 206, light 21watt osram 865, no co2 , and ferts when i saw something wrong.
    There is a lot of bba, but it look great to this tank,and dont do anything . :)
  2. nicpapa
    Mar 2, 2012
    671
    441
    6:16 AM
    Shrimp tanks , rcs , snowball, orange. neocaridina
    Light is 28 watt for 3 tanks.
    Diy ferts, co2 difuse in hang on filters.
    In rcs tank temp is very low , thats why the green algae on leaves temp is 18c.
  3. nicpapa
    Mar 2, 2012
    671
    441
    6:16 AM
    The 180lt nature style
    Light is 2 x 39watt osram, and one red.
    Filter 2 ecco pro 2036 , and co2 cerge reactor.
    Fert diy , ~ Ei .
  4. nicpapa
    Mar 2, 2012
    671
    441
    6:16 AM
    100 lt sulasesi tank .
    Light 21 watt, use salty shrimp mineral 7.5.
    Shrimps are 200++.
  5. nicpapa
    Mar 2, 2012
    671
    441
    6:16 AM
    Last four tanks. :)
    First tank topaz blue shrimps, light is 7watt led the cheap one for home :) , co2 difuse in hang on filter, no ferts, water ro , tap and mineral.
    The other 2 crs tanks,light is 18watt t8 for both tanks, in one there is co2, in the left there are 7 otos , trying for breeding, and here ro mineral, and no ferts.
    The last one with neo yellow, light is again cheap 5w led, no ferts , cos difuse in fillter ,water ro -tap and minerals.
  6. fablau
    fablau rotalabutterfly.com
    Staff Member Moderator
    Sep 13, 2008
    2,850
    621
    10:16 PM
    Wow Nic, what a show! You did a great job over there. Next time I'll go in Italy I'll organize a trip in Greece just to see your tanks :cool:
    I bet you are having fun with all those tanks, how much time dedicate a day to keep them so well?
    Also, I have noticed in your shrimp tanks you put some tree leaves to rot in there: does that help with shrimp? Do shrimp eat them? If so, that's something I never thought about...
    Congratulations for your collection again!!
  7. nicpapa
    Mar 2, 2012
    671
    441
    6:16 AM
    Haha ok .
    Yes i use dry leaves...
    Some leaves like mulberry shrimp eat the leaf after 2- days, also ansictrus.
    Other harder leaves, make a biofilm , and srhimp eat only biofilm.
    Its not need a lot of maintenance...
    Aquariums are not in the same place ... but in three, 180 liters in my office, shrimps over my office in the room, 100 anscistrus at home ... There are three different Ro waters... For example, maintenance for all shrimp tanks , I want less than 1 hour DRAIN FILLING - pruning. The 180lt 10-20 minutes. 100 liters, 10 to 20 minutes. Casual, simply go through the aquarium feed and if plants overgrown trim. Daily 5 minutes in each space ... This is the time that i see the tanks.
    2 people like this.
