Micro Fertilizer DIY Formula
AbhishekDarbari
Mar 16, 2013
EDTA not needed
No EDTA filler required. The extra gluconate in FE gluconate with chelate all the trace elements. In one on the older posts this was mentioned by Biollante. 0.16 gms of microfert in 100 litres will give a ppm of 0.1ppm FE. So based on this info you can calculate the dosing.
dodytiger
hi Biollante
I live in Egypt and there is difficulty in getting on csm + b
There are equations that after you've made and thank you very much for assistance
In Egypt, I can not find some supplementary material for any equation
This presentation of the material in Egypt
Mg:
MgSO4 ● 7H2O, Magnesium sulfate hepta-hydrate, Epsom salt,
Fe:
FeSO4 ● 7 H2O, Iron (II) sulfate hepta-hydrate,
Mn:
MnSO4 ● H2O, Manganese (II) sulfate monohydrate
Zn:
ZnSO4 • 7 H2O, Zinc sulfate hepta-hydrate
ZnO, Zinc oxide
B:
H3BO3, Boric acid
Na2B4O7 • 10H2O, Borax
Cu:
CuSO4 ● 5H2O, Copper sulfate penta-hydrate (blue4)
Mo:
(NH4) 2O, 4MoO3, Molybdic acid
EDTA, Ethylenediaminetetraacetic acid 2Na
Is there a solution to those substances
thank You very much
Aqua.heaven
Aug 21, 2019
24
Karachi,Pakistan
Hey Biollante can you please guide me how can i make my own csm+b I have following chemcials avalibale but dont have knowledge how to mix them
Manganeese Sulphate - 1 KG
Zinc Sulphate - 1 KG
Copper Sulphate - Half KG
Boric Acid - 1 KG
Iron EDTA 13% 50 grams
EDTA Seperate Chemical - Half KG
