Mgco3
Deanna
Aug 23, 2018
57
33
PA
I'd like to ask to have MgCO3 included in the calculator. Would need to show dKH and dGH as well as Mg and CO3 ppm (same info as CaCO3).
Incidentally, the CaCO3 calculations do not provide the red warnings for solubility limits.
EDIT: Oops: NVM the solubility limits, I forgot about the dependence upon pH.
Zeus
55
59
Yorkshire,U.K.
Might be worth a look at IFC calculator, has all the solubilities kH and gH added already. The calculator is not for 'newbies'
Advises you if you need to dry dose (which with MgCO3 is highly likely as its pretty insoluble) or if you exceed to tank solubility limits, I do have a Max CaCO3 alpha sheet as well which works out the Max CaCO3 you can add to tank based on tanks pH ( or how much of your rocks dissolve into you water for a given pH ;))
Deanna
Aug 23, 2018
57
33
PA
Thanks! You're right: it's not for the faint of heart. First attempt to input data stymied me ...maybe will try to figure this out another time. I have been using the Flowgro calculator for MgCO3. Of course, it's in German, but still easy to figure out. I was hoping to expand the utility of RotalaButterfly.
Reactions: Zeus
Zeus
55
59
Yorkshire,U.K.
Just like a new Operating System or changing from Andriod to Apple, just takes a little time and patience, the data output can be a little over whelming at times :eek:, but the results are the results after all ;)
