Should we start a discussion about needle and metering valves? ... About what to look for, part numbers, Cv, and whatever else pops up.
I've been using Ideal 52-1-12 needle valves. This model of Ideal works very well over a wide range.
Ideal needle valves: http://www.idealvalve.com/
I just picked up an Ideal 54-2-11 stainless steel straight through needle valve. I wonder if it will offer a good flow range. You can compare its specs with the 54-1-11 valve which has a lot of similar specs to the 52-1-12. The differences are the body material and shape.
Ideal 54 series: http://idealvalve.thomasnet.com/vie...ies-forged-stainless-needle-valves?&forward=1
Ideal 52 series: http://idealvalve.thomasnet.com/vie...-series-forged-brass-needle-valves?&forward=1
I've also used the Swagelok "M" series metering valves.The "M" series has been reported only offer control over about a 1/4 turn range. It seems the "S" series Swagelok valves would be a better choice for our use.
Swagelok metering valves - description pdf: http://www.swagelok.com/downloads/webcatalogs/EN/MS-01-142.pdf
"M" series discussion: http://www.barrreport.com/showthread.php/7368-B-4MA-Swagelok-metering-valve-adjustment-questions
Swagelok metering valves - catalog: http://www.swagelok.com/search/find_products_home.aspx?SEARCH=/search/Metering/id-10000276/type-1
