My ozelot swords appear to be melting.
I am trying a 75 gallon lowtech planted aquarium. I just recieved my plants yesterday and planted them. I used seachem prime to treat the tap water. I dosed KNO3 and KH2PO4 and seachem equlibrium per the article on non co2 methods. I also dosed a bit of excel just for the heck of it. I have 160 watts of NO t12's and the light is poorly reflected. No fish so far. I use cheapo test kits which is why I chose the EI method of dosing but here are the parameters that I'm getting
NO3 about 20ish PPM
NO2 0
GH 280 PPM
KH 220 PPM
PH 8 or so
My PH and hardness seem pretty high is it something I should worry about?
It's only been a day so I am not terribly concerned as it may just be shock of the new tank but if you can point out any glaring issues I would appreciate it.
Also in my tank are various crypts, dwarf saggitaria, pennywort, java fern, java moss, corkscrew vals, anubias nana, and a bunch of stem plants. The crypts are melting too but I read that is fairly normal when moved. The dwarf saggitaria seem like they already have grown some, and anubias nana looks very healthy as well. The smaller vals look great but the bigger vals have browning tops.
There seems to be hair algae already growing on the tips of my vals, on my java fern, and ozelot sword. The lights have only been on a total of maybe a total of 6 hours so far so I found that a bit odd. I figured withour reflectors about 2 watts per gallon would be good but maybe I should lower that.
Should I wait it out for a few weeks and see what happens or change something?
NO3 about 20ish PPM
NO2 0
GH 280 PPM
KH 220 PPM
PH 8 or so
