Max PAR without CO2
Discussion in 'Lighting' started by Yo-han, Apr 8, 2013.
  1. Yo-han
    Yo-han Guru Class Expert
    Feb 6, 2011
    285
    2:12 PM
    I installed a dimmer on my T5 a few weeks ago and arranged a PAR meter. I can get over 320 at the surface and 170 at the substrate in the front. But at how much PAR do you start CO2?
  2. dutchy
    dutchy Plant Guru Team
    Jul 6, 2009
    2:12 PM
    I've never been able to keep a non CO2 tank in shape with more than 30 mmols of PAR at the substrate. With Excel until 40 mmols.
    Everything higher means CO2 to me.
  3. Yo-han
    Feb 6, 2011
    285
    2:12 PM
    Thanks, so you would start CO2 before it hits 30 at the substrate, or would you make sure it is at his peak at 30?
  4. dutchy
    Jul 6, 2009
    2:12 PM
    I'd keep it at 30, with less some plants could get problems to grow.
  5. Yo-han
    Feb 6, 2011
    285
    2:12 PM
    I think you misunderstood. I'm using CO2, and will be using higher light anyway. But before, I could only switch the bulbs on per two. Now I'm using a flora-mate dimmer, so the question was when to turn the CO2 on. Right from the start, when the bulbs kick on at 1%, or from a certain PAR. But I'll make sure my CO2 is high when PAR hits 30.
  6. dutchy
    Jul 6, 2009
    2:12 PM
    Yes I misunderstood :eek: Some will photosynthesize at a very low PAR, even down to 12 mmols. So it's better if you start CO2 even before the first bit of light switches on.
  7. Marcel G
    Marcel G Banned
    Jun 5, 2012
    173
    17
    2:12 PM
    I agree with dutchy. Some mosses are able to grow at 6-12 mmol PAR. I also saw some weeds (egeria densa?) to survive at 5 mmol PAR, although it seemed impossible. Anubias also can survive at these levels.
  8. Tom Barr
    18,692
    721
    2:12 PM
    I would start as soon as the lights come on, as the light increases, so does the CO2.
    Then turn off the CO2 about 30 minutes before the lights go off at night.
  9. Yo-han
    Feb 6, 2011
    285
    2:12 PM
    Thanks all! Experimenting again;)
