Matheson Dual Stage and ADA glass
Discussion in 'Trades, swaps, sales' started by quincieadams, Jun 1, 2017.
  1. quincieadams
    quincieadams Junior Poster
    Dec 21, 2011
    6:14 PM
    Selling my Matheson Dual Stage 3810-540 with postbody.
    Getting out of the hobby, used for about three years. This is one of those reg you set it and forget it.
    I never had one issue with it.
    It does have some water spots, see pictures. Also, wear marks on the cga nut. Can be cleaned up.
    You can actually see the build thread here: http://www.barrreport.com/forum/barr...postbody-build
    The post body includes all brass Swagelok fitting:
    B-2-ME
    Description: MALE ELBOW
    B-4-RSE-2
    Description: REDUCING STREET ELBOW
    B-4-HLN-2.00
    Description: HEX LONG NIPPLE
    B-2C2-1/3
    Description: CHECK VALVE
    B-6M0-7-2
    Description: METRIC FEMALE CONNECTOR
    Ideal 52-1-12 needle valve
    CGA 320 Nut and Nipple from Regulator and Torch Exchange, Inc
    Burkert Solenoid Valve with Buna Seal
    You will also get four complete sets of "Tubing Insert 4ea, back&front ferrule 5ea, nut tub fitting 5ea" See pictures. These are the parts required to connect new Co2 tubing. I have an ADA check valve attached to about 14" of tubing so you don't really need to replace these but I bought them just in case. You normally would not reuse any of these parts when replacing your tubing to be sure you wouldn't have leakage..
    $325 Shipped for it all. Price these parts... You will be well over $400. Think I paid $300 for just the reg. The total cost of this build was around $500-600 bucks. It was well worth the worry free operation I got out of it.
    Also for sale
    ADA glass bubble counter -great piece. Has a little bit of buildup in the inside. Will probably clean up if you have pipe cleaners. Has 10 suction cups. $40 shipped
    ADA Pollen Glass Type-3 worked really well in my 20 gallon. Has buildup in the inside. Again, will probably clean up if you have the time. disk is in perfect conduction. Bright white, not stained. Has 4 suction cups for the diffuser and 4 to run your co2 tubing through. $40 shipped
    Let me know if you have any other questions. Hopefully someone will have as much fun with it as I did..
    Thanks! And thanks Tom for having the one site that has always been so classy and full of knowledgeable quality people.
    #1 quincieadams, Jun 1, 2017
  2. quincieadams
    Dec 21, 2011
    6:14 PM
    Bump.........
  3. kalkwasser
    kalkwasser New Member
    Sep 13, 2017
    2:14 AM
    Do you have a photo link sir?
  4. Jason King
    Jason King barrreport.com
    Nov 20, 2011
    1,569
    349
    6:14 PM
  5. kalkwasser
    Sep 13, 2017
    2:14 AM
    The photo bucket link is not working anymore.
  6. litesky
    litesky New Member
    Sep 15, 2017
    11:14 AM
  7. quincieadams
    Dec 21, 2011
    6:14 PM
    Hey not sure what happened to the pics.
    Working off my phone right now. Will get pictures back on this post this evening.
    Replied to all pms.
  8. Nikolyator
    Nikolyator New Member
    Jun 29, 2017
    2:14 PM
    hi. is it still for sale?
  9. JCarter
    JCarter Junior Poster
    May 17, 2016
    6:14 PM
    The ADA glass still for sale?
