Marsilea Hirsuta - Planting, trimming...etc
Discussion in 'General Plant Topics' started by jcmv4792, Aug 1, 2015.
  1. jcmv4792
    jcmv4792 Subscriber
    Jul 30, 2015
    3:53 PM
    I can't seem to find the answer to this anywhere. Once the marsilea is planted, should I cut off the four leaf clovers part of the part, so that the single lobe form grows? Or do I wait until it roots to do this? Is cutting it even necessary?(This is in a low tech tank)
    Also, when planting marsilea, is it okay to cut the runners and plant it deep into the substrate?
  2. Solcielo lawrencia
    Mar 20, 2013
    1,007
    44
    3:53 PM
    Leave it until it roots. The terrestrial growth will die off, then you can decide if you want to trim it off.
    And yes, you can cut runners and replant.
