Mark Stephens
Discussion in 'Introductions' started by markStephens, Aug 1, 2019.
  1. markStephens
    markStephens New Member
    Aug 1, 2019
    10:51 PM
    Hi, I have a ~20 gal really long tank made from plexiglass. It is 50" x 7"W x 12"D. There is a slate bottom but no substrate. Stem plants are weighted down. Some do really well (R. indica; Myriophyllum guyana), some not so much. Kinda an experiment. Shrimp, various nano fish, lots of snails. PPS-Pro ferts.
    CO2 injection.
    Eheim 2017 filter (at full throttle)
    4' Current USA 48"-60" Satellite Plus PRO LED Light.
    kH: 4
    gH: 8
    pH: 7.0
    CO2: ~20 ppm based on indicator
  2. Phishless
    Phishless Lifetime Member
    Jul 13, 2017
    1,116
    969
    10:51 PM
    I used PPS Pro before I began injecting CO2.
    NO3 always dropped to zero very quickly for me after pressurized CO2 introduction.
    I had to move to a modified EI recipe to keep the water column @ levels I liked.
  3. Phishless
    Jul 13, 2017
    1,116
    969
    10:51 PM
    A lower KH will always help, never zero but 1.0 dKH or a bit less.
    Most will target a 1.0 drop in pH which is roughly equivalent to 30ppm CO2.
    Meaning that during lights on pH would be around 6.0 if 7.0 is your de-gassed pH reading.
