Manganese And Calcium Deficiencies
Discussion in 'Advanced Strategies and Fertilization' started by rs18alpha, Dec 9, 2018.
  1. rs18alpha
    rs18alpha Subscriber
    Feb 3, 2017
    240
    25
    9:50 PM
    If I see these deficiencies in my plants do I add more CSM+B or buy MnSO4 and CaSO4 or CaCO3?
    I saw a chart that says to increase CSM+B if the plant needs more Manganese.
    The chart says to use CaCO3 and CSM+B if the plant needs more Calcium. I don't know if I should get CaCO3 or CaSO4 for the Calcium?
    In short, the chart says to increase CSM+B for both deficiencies, but I don't know if I need to purchase anything for the Calcium?
    Lawson likes this.
  2. Phishless
    Phishless Lifetime Member
    Jul 13, 2017
    1,116
    969
    4:50 PM
    If I were trying to raise calcium I'd just use GH Booster from Colin.
    That will cover Mg, K, and Ca.
    The Ca is from CaSO4 in the booster.
    CaCO3 will raise alkalinity, have no idea what KH you keep your water at.
    Are you sure there is an Mn deficiency?
    Mn is included in CSM+B
    Any pics of the deficiency in plants?
    I would always up macro dosing before I'd touch anything else.
  3. rs18alpha
    Feb 3, 2017
    240
    25
    9:50 PM
    Here are some pics, I hope they're good enough?
    When you say to up the Macs. Do you mean all of them?
    #3 rs18alpha, Dec 9, 2018
  4. Phishless
    Jul 13, 2017
    1,116
    969
    4:50 PM
    I'd roll the dice on a K deficiency by the brown holes with yellow around them.
    Other macro ferts could also be contributing to this, PO4 being another.
  5. rs18alpha
    Feb 3, 2017
    240
    25
    9:50 PM
    So what should I try?
  6. Phishless
    Jul 13, 2017
    1,116
    969
    4:50 PM
    Are you using a macro solution that includes NO3, K, and PO4?
    If so what are your NO3 levels? Maybe add more.
    If NO3 & PO4 is high add more K2SO4 on it's own.
  7. rs18alpha
    Feb 3, 2017
    240
    25
    9:50 PM
    Per dose I get 7.5 ppm NO3 - 2ppm K and I get 1.95ppm K from K2SO4 and 3.3ppm MgSO4
    My week totals are 22.5 N
    22.5 K
    6 PO4
    9.9 Mg
  8. Phishless
    Jul 13, 2017
    1,116
    969
    4:50 PM
    Weekly totals seem fine as long as 22.5 N really means NO3.
    Do you ever test your water?
    Lawson likes this.
  9. rs18alpha
    Feb 3, 2017
    240
    25
    9:50 PM
    I dose 7.5ppm KNO3 I do test my water, but it's been a while. I have to get better at that.
    What should I be testing for?
    If my totals are good, then what do you suggest I try to fix the problem?
  10. rs18alpha
    Feb 3, 2017
    240
    25
    9:50 PM
    I tested my water 2 hrs before the CO2 came on and right before my weekly water change.
    PH 7
    GH 11
    KH 3
    Phosphates 1.0
    Nitrates 5 ppm
    What do you think?
  11. Phishless
    Jul 13, 2017
    1,116
    969
    4:50 PM
    That's weak @ right before the water change.
    Do you front-load macros for the week after the water change?
    50% water change would bring you down to .5 PO4 & 2.5 NO3
    It takes a lot of plants in a tank to absorb 3 - 3.5ppm of NO3 per day.
    I would not be happy with this prior to WC.
    Depending on the TDS pre water change I may opt to not change any water and add macros.
    Now I wonder if micros are running this weak also?
    Ayhan Demir likes this.
  12. rs18alpha
    Feb 3, 2017
    240
    25
    9:50 PM
    After a WC. I add 7.5ppm K.NO3 - 2ppm KH2PO4 - 1.95ppm K2SO4 I dose these 3 times a week.
    I get from CSM+B 0.2ppmFe - MgSo4 3.3ppm I dose these 3 times a week.
    What do you mean front load? i think I know, but please explain.
  13. Phishless
    Jul 13, 2017
    1,116
    969
    4:50 PM
    I'm done @ this point!
    Good Luck!
  14. rs18alpha
    Feb 3, 2017
    240
    25
    9:50 PM
    Awe Phishless, I feel like we were so close. I still don't know what to do to fix my problem?
    Phishless likes this.
  15. KeeperOfASilentWorld
    Aug 3, 2017
    57
    10:50 PM
    Dear @rs18alpha ,
    Continue on doing your weekly %50 WC.
    After your water change; dose ( front load ) 20 ppm KNO3 ( 12.6 ppm K ), 4 ppm KH2PO4 ( 1.6 ppm K ), 6 ppm K2SO4 and 5 ppm MgSO4***.
    Then daily dose 3 ppm KNO3, 1 ppm KH2PO4, 1 ppm K2SO4, 0.5 ppm MgSO4 and 0.2 ppm Fe through CSM B+. Dose micros before lights on and macros after lights off.
    If you want to dose every 2 days, just double these doses. Keep in mind that it might work better if the micros were daily dosed in your situation.
    Before starting any of this, please give some information regarding your CO2. Let's make sure that the CO2 is dialled in correctly before any dosing. After a week or two, we will see where things are and adjust accordingly.
    ***Do you know how much Ca and Mg is in your GH of 11. We can adjust the Mg and Ca dose accordingly if you could find that out.
    Happy Fish Keeping :)
    #15 KeeperOfASilentWorld, Dec 12, 2018
  16. rs18alpha
    Feb 3, 2017
    240
    25
    9:50 PM
    How do I test Ca ,Mg in my Gh?
    As far as my CO2, according to my last test which was a while ago I've got about 30ppm
    I use the API liquid test kit to test my Ph and use one of those charts to find the CO2 levels. I know this isn't the best way but that's all I have.
    I'm waiting for an inline pre filter that I'll be converting into a CO2 reactor. Once I get that set up the CO2 should be more consistent.
  17. KeeperOfASilentWorld
    Aug 3, 2017
    57
    10:50 PM
  18. rs18alpha
    Feb 3, 2017
    240
    25
    9:50 PM
    Right now my Ph is 7- KH 3 so my CO2 ppm is 30 according to Rotalabutterfly
    So it looks like I need to get the PH down to 6.30 to reach 45ppm CO2
    I have a copy from my water Co. and all I can see is Hardness (mg/l 66 to 190
    or Hardness ( grains per gallon) 4 to 11 is this what you mean?
  19. Phishless
    Jul 13, 2017
    1,116
    969
    4:50 PM
    If you have an API Ca test kit you can estimate Mg using this formula.
    ((17.86 x dGH) - (2.5 x Ca ppm)) / 4.1 = Mg ppm
    (ppm dGH - (2.5 x Ca ppm)) /4.1 = Mg ppm
    Some lab tests are not so cheap!
    KeeperOfASilentWorld likes this.
  20. Phishless
    Jul 13, 2017
    1,116
    969
    4:50 PM
    Here is also the math from the KH/pH CO2 chart.
    3*KH*POWER(10,7-pH) from my spreadsheet or 3xKHx10^(7-pH) on the phone
