Hi all,
As you may know I swapped my 3x150w 6500k metal halide fixture for 2 T8 fixtures each with 4x30w bulbs.
The MH provided 50-60 micromoles at the substrate and over 100 at the water surface suspended 39" above the water surface of a 24" deep tank.
The T8 fixtures provide about 30 micromoles at the substrate and over 55-60 at the water surface suspended 6" above the water surface of the same 24" deep tank.
Some observations:
1). Growth is much slower.
2). Growth for some species is smaller but time will tell. The scape and plantings are still relatively immature.
3). There is literally NO algae anywhere of any type. Some GDA on the front glass and some brown diatoms from direct sunlight on one end pane. Previously I struggled with bouts of BBA and types of cladorpha covering the wood...
4). New growth is constant and consistently good. Leaf formation is good. No deformities in shape or color.
5). Trimming duties have almost disappeared
6). I do miss the MH shimmer and I am not sure I like the yellowish cast of these bulbs. Will be looking to replace with something better perhaps...
7). I spend LESS time playing with c02 and balancing it with the fish. It is pretty much set and forget. Just ensure the tank doesn't run out or the needle wheel tubing fall off...
8). Fish seem happier in the lower light, but I think I may be projecting
9). Growth is also thick. Perhaps not as lush as it might be for the same age as under the MH, but I am happy with it so far.
So, overall while I have lost some of the pleasure derived from larger and faster growth, remember my Blyxa?, I spend a LOT less time asking folks to take cuttings as well...
There are some plants I am sure that will not do well for me but for the most part I am using lots of java and anubias varieties along with some bolbitus and stauro....
No problems with growth so far..
I really recommend to folks to think about reducing their light levels if their goal is less trimming and maintenance. I don't stress anymore trying to ensure adequate c02 for aromatica stems that grow 1-2" daily
Thanks for listening.
Some observations:
