Low ph, Water Quality Report, a Question...
Beating Avoidance Mode
Hi Pat,
With a couple of exceptions, I think a minimum alkalinity of 4dKH is a real good idea. :)
This is somewhat controversial around here, so this is just between you and me. :eek:
pat w
Nov 4, 2009
462
Daphne, AL (east Mobile Bay)
OK, So I'm dosing sodium bicarb to raise my kH. 6 Tsp. each week into a 80 gal water column during a 50% WC. Should I be able to get a closer feel of the CO2 from the standard kH/pH/CO2 charts directly from a pH test of tank water since the lion's share of my kH now comes from carbonate?
Pat
Better Question Than I Have Answer
Pat
Hi Pat,
A good question, I wish I had a good answer. :eek:
I would think that raising and stabilizing the alkalinity should make calculating CO2 via change in pH more accurate. I guess I still would not make myself too reliant on KH/pH/CO2 charts, still best to watch the plants and critters. :)
pat w
Nov 4, 2009
462
Well ... anywho ... I see a drop in pH from around 8.3, taken just before the CO2 starts flowing, down to about 6.8 min. All critters appear happy and healthy. Plants doing well as far as I can tell.
Pat
Mumbo The Jumbo
Hi Pat,
It does seem as though you have a good level of CO2. :)
The ultimate problem with ph/KH/CO2 tables/calculators is they assume CO2 is the only actor on pH.
An aquarium, especially a young aquarium with enriched substrates, has many actors. Some by themselves are negligible but together can have a noticeable or significant effect on the pH of the water column. :gw
Calibrate, Calibrate Dance to the... Opps...A Three Dog Night Moment...
Hi Pat,
Just saw this post by Tom Barr, if you want to use the pH/KH/CO2 chart, I recall you have or wanted a pH controller to maintain CO2 levels. I think Tom Barr gives a really good method calibrate for your system. With a new system, I would recalibrate monthly at minimum for awhile until things are stable and you have a good feel for the system. :)
http://www.barrreport.com/showthread.php/5505-tank-yme-log-1?p=54730#post54730.
pat w
Nov 4, 2009
462
If I ever had (and I might have and now am having a senior moment) I've moved on to the more reliable "observe the critters and plants" method. The only reason I was asking the question above was in an effort to give myself a back check of sorts.
BTW ... The Rhizo is starting to loose ground. I'm not out of the woods yet but now it's just a general PITA as opposed to an extra strength, heavy duty PITA.
Pat
