Funny, I watched this thread for a while, but had no responses so I stopped logging in, expecting I'd get an email when a post was sent... I thought wrong! So, I ended up forging ahead on my own and so far it seems like things are mostly doing well.
I actually believe that ladder is working fairly well, just watching the size of the bubbles. By the time they get to the top, they are barely the size of pinheads, and in many cases are completely absorbed before reaching the top. I've found that with increasing the bubble count I can also make the plants pearl if I want.
Early on I was dosing KNO3, KH2PO4, and some Equilibrium. Initially the NO3 levels were getting sucked up pretty fast, but then they slowed way down to the point that I had to stop dosing it. So, the details of this particular tank are:
10G w/ 2x 10W (old) CFL bulbs
Fluorite substrate
Ludwigia repens x arcuata
Echinodorus tenellus
Staurogyne repens 'Tropica'
Cyperus Helferi
Blyxa japonica - never did much
some old crypts I don't remember the name of that you can't kill if you try
An apogneton bulb, think it is ulvaceus or something like that -- took over the entire tank so it was moved to a 30g tank.
Najas roraima -- has basically done nothing at all
Lilaeopsis mauritiana
I initially had some phyllanthus fluitans (red root floater), but it eventually melted in to nothingness
I initially had some Hygroryza aristata, but eventually all leaves died and I finally pulled it out -- otherwise I loved this
Some ancient java fern that is slowly recovering
I also recently added some frogbit and that is doing awesome.
The main issue I have right now is that some BBA is showing up in areas and seems to be slowly spreading, little tufts at a time. I removed a bunch of leaves the other day that had it on it, but it is also on some rocks. Not sure how to get rid of it really at this point. I believe this is partly caused by unstable CO2 levels? If so, that is very possible due to some water circulation issues I should be addressing today.
Otherwise, most of the plants are doing quite well, with the exceptions noted above. The crypts have exploded with leaves reaching the surface now. The ludwigia has to be trimmed every couple weeks as it grows like mad. The micro sword and lilaeopsis try to take over the tank if I let it.
The denizens of this tank currently consist of 6 celestial pearl danios (started as 6, now up to 12 due to some eggs not getting eaten), 1 really old male guppy (I finally tossed a female in for him), 2 hillstream loaches, 4 otocinclus, and initially about 10 regular cherry shrimp... which has now grown to probably 50+ of them.
All in all, doing fairly well, other than the BBA. Just recently I noticed the cyperus helferi is not turning as dark green as it was. It is more of a light green with a yellowish tinge, but it is still growing. I checked the NO3 levels the other day with a test kit and they came in at 20ppm, been dosing K, so not sure what else it wants. I also noted that some of the frogbit leaves also seemed to be yellowing some, or in some cases showing holes in them. Not sure what is up with that either at this point.
--Robert
