Low levels of CO2 even using a pressurized system
For100
Feb 5, 2011
35
10
51
for the past few months I have struggled to maintain the proper CO2 balance. I have several CO2 readers in my tank and these barely turn green despite a large dose of CO2 (3+ bubbles per sec). My plants are doing OK, but not great. I see BBA growth in some areas (corners and driftwood). Anything that requires CO2 fertilization is doing poorly.
I wonder what might be the factor for this change in the balance in the last 6 months.
Here are the details of my tank:
1.- 180 gallons with 2 overflows.
2.- Sump/Refugium with 1200GPH pond master pump, net flow of ~500GPH.
3.- Pressurized CO2 cilinder and regulator.
4.- pH controller, CO2 in-line reactor using a pond master 700GPH pump, inlet and outlet inside sump tank.
5.- Parameter are set at GH 5, KH 4 and pH of 6 to 6.1.
CO2 is consumed at a faster rate than before, but I cannot find to get the right balance.
the tank consumes about a 10lb CO2 cilinder in about 6 weeks. I found this rate extremely high compared to past experiences.
Should I restrict the flow of the sump pumps to avoid surface gas exchange?
Is the carbonate hardness to low? How do I increase the dissolved CO2 without having to decrease pH further down?
Is the rate of consumption too high?
Any ideas are welcome.
Freddy
I will post more later, but 3 bps for a 180 with twin overflow is NOT enough.....I would NOT consider that a 'large dose' of c02. For a 20 gal tank, perhaps :)
It is also a balance between c02 and 02 that is required....
sandeepraghuvanshi
Nov 8, 2011
73
Although I do not have much experience, but isnt overflow and sump considered bad for planted tank.
They might be causing loss of Co2.
Also one of my friend used a splitter in Co2 setp and introduced co2 from 2 sides to ensure co2 reaches all parts of tank
Snivi
Mar 15, 2012
13
10lb CO2 cilinder in about 6 weeks at 3 bps ? :(
you must have a leak somewhere in your co2 tubing befor your counter
H
Htomassini
Do you get many bubbles out of the co2 reactor? I think you may be pushing too much 700gph. Try running it half using a ball valve. Also 3 bps is too low for. 180 like Gerry said. Check for leaks though.
Henry tomassini
www.theplantedaquariumstore.com
Sent from my iPad using Tapatalk HD
Matt F.
2,319
California
If you want to measure by BPS, I'm running between 5-6 bps in my 17 gallon. ;P
BPS is not an accurate measure of CO2 levels in an aquarium.
I don't consider drop checkers to be either.
30-40 ppm CO2 is an arbitrary number. 4dkh and 5 dkh fluid mixed with bromothymol blue only assures us that there is 30 (4dkh) or 40 (5dkh) in our tank an hour or two before.
The only time I've used a drop checker was to make sure I was hitting a minimum of 30ppm co2 in a tank, and then I removed teh drop checker and slowly increased CO2 till the plants responded well. You have to do this carefully b/c if you adjust too fast the fish will have problems and hang out towards the surface gasping...
As Tom has shown us, many tanks are fine with quite a bit more CO2 (60-80+ ppm).
I agree with Gerryd. Def not enough CO2.
DEF a leak somewhere. A 10# co2 tank should last you 5-6 months at twice what you are injecting.
