Lighting Recommendations for 4ft. 70 gallon.
Discussion in 'Lighting' started by kevinmichael77, Oct 21, 2015.
  1. kevinmichael77
    kevinmichael77 Guru Class Expert
    Oct 5, 2012
    385
    7
    3:25 AM
    As the title says I'm looking for recommendations to light my four foot tank. I'm looking for medium light range as I probably won't do CO2 in the beginning and if I eventually do at CO2 it will be very minimal. I was to keep the tank pretty low maintenance and may even just go the excel route.
    Tank is about 18" tall and I think I want to stay away from LED's at this point. May add one just for color but later down the road. Flora won't be anything to extravagant but may want a carpet of hairgrass or something down the road.
    Any help would be appreciated!
  2. Dennis Singh
    Dennis Singh SynKing!
    May 5, 2013
    2,417
    639
    7:25 PM
    A cheap dual industrial t8's would be good easy start
    my rec
  3. kevinmichael77
    Oct 5, 2012
    385
    7
    3:25 AM
    If I decide to go with T8's will that be enough if I decide to inject CO2 eventually? I don't want to break the bank with a light fixture but I'd like enough lighting to inject small amounts of CO2 in the future if I so choose. Would two 4ft Sunblasters be enough to inject light CO2? I'm using two 3ft fixtures over my 40b just dosing excel and ferts here and there with seemingly no issues. For this tank I won't be doing any real difficult plant species I don't think.
  4. Dennis Singh
    May 5, 2013
    2,417
    639
    7:25 PM
    The lower the light along with co2 the better, you will see a nice enriched growing aquarium, with higher light=higher upkeep, uptake, more more of everything, its harder to get consistency. For anyone starting a low tech I'd recommend lower light with light co2 you can see the range (colors, growth) compared to higher tech (lighting)
  5. kevinmichael77
    Oct 5, 2012
    385
    7
    3:25 AM
    Are there any fixtures you could recommend? I'd like to get something that looks nice as it will be in the living room. Also it will most likely need to be hung from the ceiling.
  6. Dennis Singh
    May 5, 2013
    2,417
    639
    7:25 PM
    Not nice ones no, i just recommended shop lights.
    DIY? You good with? t8's, t5's t12's all pretty simple mechanism constructed, just a ballast, those cone wire connectors/attachers, cord/plug and build the exterior can make a nice looking one
    if your too lazy with that
    hmmm
    something that looks nice? Maybe go leds? Two 48" planted plus or 1 ray 2 (but light spread won't be as good)
    light spread doesn't seem to come up much, it should though
    cheap?
    a single or dual odysea t5
    um...
    Theres plenty of nice fixtures out there by the different teams
    I bet Barr would know em since he posted that light timeline postymajigg
  7. UDGags
    Sep 13, 2009
    630
    37
    3:25 AM
    I use the ATI sunpower units, not cheap but look slick and will be good for anything you want to do including saltwater.
    Here is a picture from a couple years ago that show them.
    [​IMG]
  8. kevinmichael77
    Oct 5, 2012
    385
    7
    3:25 AM
    ATI's are nice but extremely out of my price range!!
    I'd like to light the tank in about the $150 range and think I want to stay away from LED's right now.
    I don't like the looks of shop lights so I was hoping someone had a fixture they liked that was reasonable. Something maybe designed for hydroponics. I do want good spread but again it's 48x18x18.
  9. UDGags
    Sep 13, 2009
    630
    37
    3:25 AM
  10. Dennis Singh
    May 5, 2013
    2,417
    639
    7:25 PM
    Yeah this is how the pro's do it that don't buy all the ada equipment. horticulture t5's 4 bulbs or 8 bulbs, hung from ceiling or conduit. The spread is great from what I see. My next spenditure after co2 regulator. I know 3 people that do it this way and they're all great growers. but then again, this is higher tech then you want...
  11. kevinmichael77
    Oct 5, 2012
    385
    7
    3:25 AM
    Any brands or sites that I could check out for these fixtures?
  12. UDGags
    Sep 13, 2009
    630
    37
    3:25 AM
  13. kevinmichael77
    Oct 5, 2012
    385
    7
    3:25 AM
    Thanks so much!! If I went with the 4ft 4-bulb fixture, what do people usually use for bulb combinations?
    Also I'm assuming I'd have to hang this well above the tank if it's 4x54w.
    Kev
  14. UDGags
    Sep 13, 2009
    630
    37
    3:25 AM
    I use combinations of the following in my 8 bulb units
    Giesemann PowerChrome Aqua Flora T5 Lamps
    Giesemann PowerChrome Midday T5 Lamps
    ATI Blue Plus + T5 HO Aquarium Lamps
    ATI Purple Plus T5 HO Aquarium Lamps
    GE Starcoat 6,500K and 10k T5 High Output HO Aquarium Bulbs
    UVL Reds
  15. kevinmichael77
    Oct 5, 2012
    385
    7
    3:25 AM
    Hmm. So for 4 bulbs should I do a 10k, 6,500k, and aqua flora and what should I do for a color spectrum? Probably won't have too many red plants, if any it would prolly be alt mini. Also I'll have some Cardinal tetras and some sort of colorful apisto.
  16. UDGags
    Sep 13, 2009
    630
    37
    3:25 AM
    The bulbs you listed have decent spectrums. I would just double up on the aquaflora or buy a couple others and see what you like to your eye.
  17. kevinmichael77
    Oct 5, 2012
    385
    7
    3:25 AM
    Perfect UDgags! Been a great help. I appreciate it!
    2 people like this.
  18. kevinmichael77
    Oct 5, 2012
    385
    7
    3:25 AM
    Think the 4ft 4-lamp HO fluorescent grow light fixture would work well? Price isn't bad and I can change the 6,500k bulbs out when I get some cash. Not horrible looking either. May be able to spray paint it black.
  19. kevinmichael77
    Oct 5, 2012
    385
    7
    3:25 AM
    Or I see they have a t5 vho fixture as well.
  20. kevmo911
    kevmo911 Member
    Oct 19, 2010
    67
    3:25 AM
    The 48" Planted+ is supposed to have PAR readings somewhere in between the Ray and Ray2, probably closer to the Ray, according to the guys at Finnex. Apparently the new red LEDs they used in the Planted+ model are just outside the range that a standard PAR meter will pick up, so actual PAR will be higher than measured by a bit. Best guess for a Planted+ is 50-55 PAR at 18 inches for a 48".
