Light For Low Tech 75 Gallon - Help Please
ElGecko
Sep 16, 2018
41
Florida
Hello all, thanks in advance for the sharing of expertise. I’m a plant newbie and looking to have my plants succeed in a standard 75 gallon low-tech setup.
I inherited a Fluval Aquasky LED (specs and estimated calcs attached). Is this enough for low-mid light plants?
Do I need to upgrade to Fluval Plant LED 3.0, or is this overkill?
Thank you for your thoughts!
Phishless
1,116
970
Arnold, MD
Think # of bulbs should be 84 & watts per bulb .4
The resulting calculation is about the same.
17PAR is definitely low light.
What do you intend to grow?
Reactions: ElGecko
ElGecko
Sep 16, 2018
41
Florida
Here is the desired list:
Monte Carlo
Staurogyne repens
Corkscrew vallisneria
Italian vallisneria
Anacharis
Moneywart
Dwarf Sag
Wisteria
Anubias
Java Fern
Stayed mostly in the low-medium category. Question is whether I’m too low with the Aquasky?
If I upgrade to the Fluval 3.0 Plant LED, will I now be at too much light for low tech (no Co2)?
Phishless
1,116
970
Arnold, MD
Monte carlo & s.repens I would question.
The rest should be no issues.
Would think 30PAR could get away without CO2.
ashtonfitzgerald
Sep 7, 2018
6
Oshawa, ON Canada
I agree that the Monte and S. repens may have a tough time at 17 par, but worth trying. All others should do fine. Good substrate will help plants as much as good light will.
