As someone who has seem many lighting types go the way of the Dodo bird, I'm a bit timid when it comes to buying the newest most $$$$ lighting out there.
Still, I have been thinking and pondering the LED DIY lighting for my tanks.
One reason is the shimmer effect, I have always liked this but the HQI are way too intense and poor spread.
2nd reason is cutting the lighting bill in 1/2 but getting the same PAR.
3rd is being able to try out a few different color combos and adjustments
4th is redoing the light bar to make it look discrete. I was thinking of using aluminum L square corner brackets to link 1" square hollow aluminum pipe. Then painting this to suit. I'd like to attach the light bar to rear of the stand, but have it come off the corns so you cannot see the bars from the front pane of the glass. I think I can do this and not have the bars get in the way or be ugly on the sides of the stands.
Be nicest to simply suspend the fixtures from the ceiling, that will be a year or two off till I'll be in a situation to do that.
