Leaves drooping at lights on
scottward
Oct 26, 2007
958
10
Brisbane, Australia
Hi Tom,
Hopefully this is an easy one for you...
I have been watching my plants carefully and have noticed something. I am not sure if it is normal or if it is a tell tale sign of something.
I notice that my H.Polysperma leaves look fine at night before lights out. When I check on the leaves during the morning, they still look fine with the tips pointing more or less straight up. But, when the lights come on at 2pm (CO2 on at 1pm), they droop straight down and only gradually start to pick up again after several hours.
What could cause this? This is not normal is it?
Scott.
I think it might be a night response, they close up and then open up in the light.
Hi Scott,
That is interesting that they unfold and then dip down before going up again.
I have this plant as well and my lights also come on at 2 pm and off at midnight.
They do close up at night and open during the photoperiod, but have never seen them point downwards. Can you supply a pic of this?
As Tom stated, most stems will fold their leaves up, which I take as a sign that their assimilation period is done for the 'day'.
I have also seen that they will adjust the timing of this to the photoperiod, regardless of the actual time of day..
scottward
Oct 26, 2007
958
10
Brisbane, Australia
Hi Tom/Gerry,
I'll be able to get a pic, but not until the weekend.
Yes, I thought it seemed a bit strange, I'm sure it's not 'normal'.
By about 11pm at night, the leaves are starting to fold upwards, i.e. leaf tips pointing up towards the lights. This looks normal to me, like the leaves have indeed had their 'fill' for the day.
Next morning at around 8am they are still more or less pointing upwards, again, this looks ok to me. They continue to look like this, maybe gradually coming down a little bit, until the lights come on at 2.
Once the lights have been on for an hour or so, the leaf tips are pointing in the exact opposite direction - i.e. at the gravel!!! It is as though the leaves have all suddenly become limp! (will get a photo if my description still not clear?)
Another couple of hours goes by and they then come back up again and look 'normal'.
Could it be that when my lights come on at 2pm, even though I have had the CO2 on since 1pm, that the CO2 levels are suddenly being reduced very rapidly by the CO2 starved plants? Perhaps putting the CO2 on earlier or something is the key?
But - putting the CO2 on 1 hour earlier seems pretty standard practice to me??
Also note that it is only really the H.Polysperma that is doing this. The other plants in the tank seem to be ok.
Scott.
Scott,
No, the description is clear enough, would just like to see a pic, that's all.
My c02 comes on about 90 minutes prior to lights on, but my leaves NEVER have pointed at the substrate....Many folk have the c02 come on early so that c02 levels are better for when the photoperiod begins........
The leaves pointing at the substrate is the abnormal thing IMO. I have never seen this behavior.
All stem plants that I have kept open/close their leaves on a daily basis as you describe.
It is the pointing down that is interesting.
Is it a new plant and not yet established? Could the petiole be weak and is causing the 'droop'?
Is it in an area that is low on current and/or c02? If you take a stem or two and move it to a different area, does it behave the same?
scottward
Oct 26, 2007
958
10
Brisbane, Australia
It's not a new plant - been in the tank for a couple of months now. Originally I was having a problem with just the cuttings doing this, but much worse, in that the cuttings would disintegrate completely, but I added more CO2 and that seems to have sorted that issue out.
The plant is not in an area of low current - the leaves are swaying in the current and the tank looks like a glass of champagne! CO2 is fed directly into the intake of a powerhead which is blasting the mist all over the tank and is circulating it well.
I haven't tried moving a stem or two to a different location, but I suppose this would be worth a try.
I have turned up the CO2 even more - I'll post a seperate thread about this as I have some additional questions.
Regarding this issue - could is simply be that the CO2 is more stable than it originally was when the plants were disintegrating completely, but still not quite stable enough? As Tom suggests, the closer I get to 30ppm the more 'wiggle' room I'll have.
Scott.
scottward
Oct 26, 2007
958
10
Brisbane, Australia
Hi Guys,
Attached, finally, is a photo.
Recall that the plants look fine first thing in the morning after being without light since midnight, but after a few hours the leaves start to hang down.
They pick back up again, but it's not until CO2 and light have been on for several hours.
Note all the horrible algae growing all over the leaves too.
I know Tom keeps saying CO2 CO2 CO2, so tonight I've cranked the CO2 up even further. The bubble counter looks like a spa bath.
Scott.
fjf888
Oct 29, 2007
294
Northern Virginia
I am not sure that your Hygro is a CO2 problem, not all the leaves are drooping, either. It looks like it has large leaves and reasonably healthy. I have found H. Polysperma to be a weed of epic proportions to the point that I had to tear it all out because it was too much to maintain. Increasing the CO2 will likely help the algae issue but also drive mad growth of the H. Polysperma.
You may be able to more quickly resolve the algae issue by adding flourish excel at the recommended dosages. Still it takes time for conditions to improve. Once you have the CO2 steady for conditions to improve you really need give it two to three weeks, with good CO2, EI, water changes, maintenance, etc.
scottward
Oct 26, 2007
958
10
Brisbane, Australia
Hi Fred thanks for your advice.
I'm really wondering whether this is a CO2 problem. The CO2 level in my tank *must* be high enough now. If I turn it up just slightly more the fish start gasping - the point at which fish start gasping is higher than the maximum amount of CO2 that plants can use, so, there must be *plenty* of CO2 in the water.
I'm not using a drop checker or doing water tests or anything here - just simple observation and logic.
My water circulation is good also, as I have a large powerhead causing the plant leaves to move about.
It has to be something other than CO2.
But what?
Tom have you seen this happen with H.Polysperma leaves before?
Scott.
scottward
Oct 26, 2007
958
10
Brisbane, Australia
I think I have figured this out. ;-)
CO2 problem.
I think the CO2 'response time' is the problem; I'm not getting it 'up there' fast enough at start up.
The light bulb has come on.
Tom - have I hit the nail on the head?
Scott.
Even if you have not, it will improve the overall tank.
So it's a step in the right direction regardless.
Try and see.
Regards
scottward
Oct 26, 2007
958
10
Brisbane, Australia
Try and see.
Regards
Ok, thanks Tom.
Will see what I can get set up, and will advise the outcome (so that if anybody else stumbles across this thread in the future they can get 'closure' of the problem/solution).
scottward
Oct 26, 2007
958
10
Brisbane, Australia
Hi Tom and team.
I have the AM1000 etc all running ok. Generally the plants are doing well.
I'm still having this problem though where the H. Polysperma leaves droop right down about an hour or so before the lights come on and then gradually sort themselves out.
Would the plants be trying to photosythensise somewhat in the normal room lighting? The tank is fairly near a window??
I am still scratching my head as to why this could be happening, the problem starting before the actual aquarium lights come on.
The Hygro is otherwise growing fine, I am trimming it and now replanting the cuttings and the cuttings strike and grow ok.
It appears that all the individual Hygro plants do this, but none of the other species of plants in the tank.
If I can figure this out I'll be really happy!
Scott.
