  1. Dismiss Notice
Labels and dates
Discussion in 'CO2 Enrichment' started by Gerryd, Feb 16, 2014.
  1. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    5,624
    10:56 AM
    Hey all,
    Well in the last week I had to refill all 3 of my c02 tanks. I finally got around to sticking a label on each with the date the c02 tank was hooked to the reg and used. Noticed today on the 5lb hooked to the 57 gal and dated 2/7/14 was empty......While the tank IS doing well, I don't recall the bubble rate being that excessive, especially in light of my reduction of said rates on all 3 tanks.
    So, I think this may be a clue to some issue or other and I will check into it tomorrow when I hook up a new tank and do a leak and overall check/inspection.
    I will post what I find.
    Later.
  2. Matt F.
    May 30, 2009
    2,319
    10:56 AM
    Yes, I do that with all my CO2 tanks as soon as I swap them. But instead of a label, I write directly on the aluminum tank with a magic marker. When the time comes to refill, you use alcohol to wipe the magic marker off. A 20# CO2 last about 1 year for me on a 20 gallon. Now that I have reduced the bubble rate to nearly half of what I was injecting, I expect to see a vast improvement of CO2 consumption. My tank is actually doing better than it was when I was injecting over twice the amount of gas. Plants look more colorful and growth has increased.
    That said, a couple weeks on a 5# CO2 tank doesn't sound right. IIRC a 5# tank lasted over 3-4 months for me before needing a refill, and that was on a 20 gallon at a higher bubble rate. You either have a leak somewhere or your gas tank wasn't full (maybe a relief valve dumped gas?). If you're using hose barbs rather than a tube adapter, that connection could be the culprit. Make sure your solenoid is closing at night, too. Still 2 weeks on a 5# bottle means you're losing a lot of gas somewhere.
    ALso check the CGA to make sure you don't have two washers and it's tightened down with a wrench, etc. I'd replace that washer, too.
    #2 Matt F., Feb 18, 2014
  3. Gerryd
    Sep 23, 2007
    5,624
    10:56 AM
    Hey all,
    I think I found the issue. Recently I stopped using the permaseal washers that screw into the tank itself with the more common plastic ones.
    I forgot that you can crank down on these whereas the permseals break the o-ring/brass easily if overtightened.
    When I went to remove the reg, it was little more than hand tight....which is not good :)
    So, I used a new washer (I replace each time anyway) and then cranked down on it properly (I hope).
    I also replaced all of the tubing from the inline check valve to the NW pump. Over time it gets hard being submerged, and can constrict a bit.
    It looked ok, but I replaced it anyway. I saw my bubble rate was higher than I thought, so I reduced that as well. I will monitor as usual.
    I will post if the tank again only lasts a 1 or 2...
    I think the washer was the root cause..
    We will see.
    Later
    - - - Updated - - -
    Hey all,
    We will see.
    Later
Similar Threads - Labels dates
  1. Tom Barr
    68
    882
  2. Gerryd
    231
  3. Jim Miller
    114
