After dealing with moderately soft water, and now hard water I have noticed a similarity in the doseing solution required for better plant growth.
With both water sources I have used the ratios of NPK suggested in EI scaled back for my low light application. Soft water growth problems were relatively easy to solve by doseing Ca and Mg with each waterchange.
But here in Orem Utah, the water is quite hard and I had issues with getting good growth again. With more than the recomended K doseing for even high fish load systems I still had deficiency symptoms. Even when I got that to go away (I doubled the K) I still didn't have very good growth. Only after adding plenty Mg have I gotten reasonable growth.
I know for systems with CO2 added there is a minimal gh requirement generally supplied by adding a CaMg mix both to keep the ph stable and to supply the plants with those nutrients.
If your tap has high Ca is there a minimum Mg and K level needed for the plants to be able to access those nutrients? What would that ratio look like?
If x Ca in tap then z K and y Mg nessasary for good plant growth.
Given that EI addresses the NPK ratio, could the relationship between Ca Mg and K explain why some tap sources grow plants more easily than others?
