Kitty proof Ideal needle valve?
Discussion in 'CO2 Enrichment' started by Gerryd, Jul 19, 2011.
  1. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    3:15 AM
    Hi all,
    So....................
    Even though the c02 tank and regulator is UNDER the cabinet, my cats have managed to reset the bubble rate HIGHER than it was. I had it marked and I know my bubble rate and knew immediately it was off.
    Almost a FULL turn of the valve!!!!!
    I have seen them rub their faces on it before when I was building them but wasn't sure if they did it since..I guess I know now :)
    So.......
    Any ideas to lock the knob down?
    Seriously!
    Thanks!
  2. Left C
    Left C Lifetime Members
    Sep 26, 2005
    2,510
    3:15 AM
    Would a needle nose pair of vice grip pliers work? Clamp the Ideal needle valve handle somewhere and then zip tie the handle of the pliers to something. This way, they might me able to knock it around maybe ⅛ of a turn or so, but they can't turn the handle of the needle valve by a complete revolution or anything like that. (If not needle nose vice grips, maybe a regular pair of vice grips.)
  3. fjf888
    fjf888 Guru Class Expert
    Oct 29, 2007
    294
    3:15 AM
    Ha! Too funny.
    You could baby (cat) proof the cabinet maybe with some device :)
  4. ShadowMac
    ShadowMac Lifetime Members
    Mar 25, 2010
    1,043
    12
    3:15 AM
    I think your best bet would be a kitty proof cabinet.
  5. Tom Barr
    18,648
    556
    3:15 AM
    Put Cat nip on the valve:)
  6. Gerryd
    Sep 23, 2007
    3:15 AM
    Hi all,
    LeftC, not a bad idea.
    Fred and Shadowmac, the back of the cabinet is totally open, but a nice idea if it was enclosed.
    Tom, NOT one of your better ideas :)
    I need cat AWAY spray...which I know they sell and I may give it a try...
  7. Left C
    Sep 26, 2005
    2,510
    3:15 AM
    You can pour some dog wee back there. :)
  8. ShadowMac
    Mar 25, 2010
    1,043
    12
    3:15 AM
    how about constructing a box with a hinge within your cabinet for the CO2 rig? You could open it, or even construct a window to see the bubble counter and close it when not making adjustments. A simple latch would keep the curious cat out.
  9. jaidexl
    jaidexl Prolific Poster
    Oct 17, 2006
    79
    3:15 AM
    The answer to your problem is too easy, because I deal with it all the time. My cat not only rubs on things, he chews them like a dog. Just swab some tabasco sauce on the valve handle and they will steer clear, no problem. But make sure to wash your hands when you adjust it. ;)
  10. Gerryd
    Sep 23, 2007
    3:15 AM
    Hi jaidexl,
    That is a good idea......
    I bet my bozos will like it though :)
    Mine aren't chewers but they will get into anything.....
  11. oldpunk
    oldpunk Guru Class Expert
    Dec 1, 2009
    427
    3:15 AM
    You could just put a couple turns of packing tape around the end. I hope you have your cylinder safely secured. I be more worried about it getting knocked over.
  12. Gerryd
    Sep 23, 2007
    3:15 AM
    Hi oldpunk,
    Yes the cylinder is secure :)
    Thanks for the caution!
  13. Left C
    Sep 26, 2005
    2,510
    3:15 AM
    I found the perfect cat deterrent. Forget cabinets, hot sauce, catnip, vice grips and such. It is a for real cat repellant!! It's called Shake-Away Coyote/Fox Urine Granules Domestic Cat Repellent: http://www.shake-away.com/DomesticCats.php?page=DomesticCat
    Shake-Away Coyote/Fox Granules are effective in repelling cats. If you need to get rid of cats, just sprinkle Shake-Away Coyote/Fox urine granules near the problem area and watch cats run for their lives.
    Shake-Away Coyote/Fox Urine Granules works on critters instinctual fear of lurking predators. By applying Shake-Away you are mimicking a predators habit of marking their territory, which activates the unwanted cat's instinctual fear and habit to flea, driving cats far away from your personal space.
    Shake-Away repellent granules have an odor that signals danger to all pest critters and are less messy than liquid. Patented formula won't burn plants, bushes or trees, wooden floors, tiles and carpets. Heavy granules won't wash away in rain - and they're naturally moist for better "cling." Granules last longer, smell stronger, and won't evaporate or freeze like liquid. Shake-Away uses the strongest force in nature to get rid of your problem animal... instinctive fear. Shake-Away contains the scent of your animals most feared predator. Easy to apply granules can be shaken right from the container to the ground or floor. Makes no mess. 100% Organic and safe. Does not harm the animal you are repelling. Guaranteed protection for small gardens, flower beds, yards and aquarium stands. This formula is designed to repel Feral or Neighborhood Cats. The 20oz container will put down a line of protection up to 600 feet long.
    Highlights:
    • 20 oz. coyote and fox powder will keep away domestic cats
    • Protects a Large Area One 20oz container goes a long way - up to 600 linear (straight line) feet covers up to 6,000 square feet.
    • 100% organic, 100% natural, 100% safe, will not harm animals
    • Unlike liquid forms, coyote and fox powder stands up against the elements
    • Remains effective in all weather conditions
    • Animals are not afraid of bad taste, they are afraid of predators
    • Bottle
    • Active Ingredient (1%): Garlic Oil
    • Inert Ingredients (99%): Urea,Calcium Carbonate, Water
    • Easy to apply powder – Applies in just minutes.
    • Makes NO mess of you, your landscape or your home.
    • Safe to use around children, pets and plants - 100% Organic
    • Does NOT harm the animals you are repelling
    [​IMG]
  14. ShadowMac
    Mar 25, 2010
    1,043
    12
    3:15 AM
    there could be other...entertaining uses for this....
