The kh out of my tap is around 3 degrees. The ph is greater than 9 out of the tap. Over a few days, the ph drops to about 7.1 when in a tank. I have 2 ph meters that i have check all my ph measurements on. My GH is about 6 degrees. This tank is a 26 gallon bowfront.
I've noticed that my KH drops to sometimes below 1 degree over a week or 2. I do regular 50% water changes once a week and KH still never get over about 1.5 degrees (i am using a calibrated test kit and use double the amout of water to test to improve accuracy). I add bicarb sometimes to bring the kh to right around 2-2.5 degrees when i see it fall below 1. I also also add 5ml of mixed P/K and 5 ml of CSM+B as per ei dosing for a 26 gallon tank. I do not add any N because there is between 15-25ppm during the week due to fishload. I have ecco complete red as my substrate. I run pressurized co2 with a controller to acheive around 30ppm of co2 using the cal aqua double drop checker. The ph of the tank after co2 injection is right around 6.
I don't add anything else, there are no rocks or anything else that could effect ph/kh that i know of in the tank. I used to add PH down to get the tap water down some before putting in the tank, but that was well over 2.5 months ago, and i figured with all the water changes this would be gone from the water, but i'm not sure. Any reason for my KH to continually drop the way it does? Is this at all normal?? The only reason i add bicarb is because over time i'd have to lower my ph to around 5.6-5.7 when it drops to keep 30ppm of co2 in the tank. While i know this probably isn't bad for the fish as it's a discus/south american setup right now, it still seem kinda low when the ph gets to the mid 5's.
I do have good circulation in the tank (Eheim 2115 and a penguin 550 powerhead) and i inject co2 into the outtake of the Eheim's spraybar using an aquamedic reducing t which has been working well.
I do not mind having to add the bicard to keep the ph/kh up, just want to find out why it is dropping as i haven't heard this to usually be the case. Oh, at water change time the only thing i add is prime. I also about once a month use excel at a slightly higher dose everday for a week to controll algae, which there is very very little, and practically none after excel treatment. Lighting is not important in this case and i don't have any issues, but i run 2 24 watt t5's for 10 hours with a noon burst of 4 bulbs for 4 hours.
I would like to not have to alter the ph controller/or add bicarb to keep the co2 consistant, but i have no problems doing either in a controlled enviroment, and have never had a problem with pressurized co2.
Is this not even a problem? Should i just do water changes and let the kh adjust to what ever it will over time and just set the ph controller at a lower ph?
This is for anyone to answer that has any advice, and sorry for the post being soo long, i just wanted to be complete and list everything that is goin on in the tank. I am an engineer at heart so i really get into the testing side of the hobby to varify what i am observing, but do realize it's how the fish and plants are doing is the important thing. I also keep different species of snails in my aquariums and was wondering if a very low kh will ultimately have an effect on their shells or health.
Thanks!!
Stevie D
Thanks!!
Stevie D
